'69 deck lid hinge problem
Old Jul 25, 2015 | 11:13 PM
69C3dreaming's Avatar
69C3dreaming
Default '69 deck lid hinge problem
The hinge mounting tabs for the two upper bolts looks to have been slotted by a PO and the bolts had oversized washer. The reason being the holes on hinge are about 1/2-3/4" higher than the body holes going into the gutter. I see suppliers sell different deck lid hinge nut plates, 68-70 and 71-75? Would the hinge be different as well? Maybe PO put on a set of later hinges? Any information on differences between years is appreciated.
Old Jul 26, 2015 | 10:36 AM
69C3dreaming
Here's a picture of the cut mounting holes.
Old Jul 26, 2015 | 11:03 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
That's going to be a hard one. Originally there were the following.
68-69 3930348
70 3958890
71-75 3995021
I've always thought they enter-changed with each other without issue and possibly the po of your car was just trying to get more adjustment out of the hinge. This is common when you are working with a car that has had previous damage.
We had to fix one last year that was a complete mess. If you are on facebook you can view this and the repair at this link: https://www.facebook.com/media/set/?...6912924&type=3
Willcox
Old Jul 26, 2015 | 11:33 AM
69C3dreaming
Thanks for the reply. I picked a bad apple..car is early Vin 11/68 build, drive train is off a 7/69 everything else is all over the place year wise.
To '69 deck lid hinge problem
