Tire Balancing Beads
Old Jul 29, 2015 | 09:09 PM
edk136's Avatar
edk136
Default Tire Balancing Beads
Made an appointment with the tire shop to get my tires switched over to the old school ET aluminum slot wheels. While talking to the guy about wheel weights, I told him there should be enough clearance for the tape weights since I had to use a spacer. He asked if I wanted to use balancing beads in lieu of tape weights to balance the tires. I was wondering if anyone had experience with the balancing beads.
Eric
Old Jul 29, 2015 | 09:28 PM
rebel542's Avatar
rebel542
I've used them in motorcycle tires with no problem and they seem to work.
Old Jul 29, 2015 | 09:51 PM
hugie82's Avatar
hugie82
My Brother in law swears by them. He has them in is ram 3500 and his Honda Goldwing. Personally I like to do regular wheel balance with aluminum mags and instead of putting weights on the outside, there's usually enough back space to put the weighs in from behind up against the mag face. Then the inside weights put them where you normally place them. Finding an a hole shop that will take the time doing it and doing it right is the hard part
Old Jul 30, 2015 | 09:57 AM
gungatim's Avatar
gungatim
yep. have used them many times. you can buy dynabeads or the cheap way to go is just use airsoft pellets...
Old Jul 30, 2015 | 09:26 PM
nomoyellowfootprints's Avatar
Veteran: Marine Corps
Finalist 2021 C3 of the Year - Modified
Default Counter Act tire balance beads
I use Counter Act tire balance beads in everything...Peterbilt, Corvettes, Dodge RAM, Jeeps and all trailer tires. I have never had a problem with this brand in over 15 years. The 4oz bags are usually the most common for our Corvette applications. You might try Grismer Tire or any of the semi truck tire places along I75. Someone has them locally.
Old Aug 2, 2015 | 08:09 PM
edk136's Avatar
edk136
So, to the guys who have used the beads, did you have any issues with the tires being unbalanced at slow speeds. Like less than 35-45 mph?
Eric
Old Aug 2, 2015 | 08:19 PM
Eric
Not really. I've used these mostly on my larger tires. However my BFG 's on my C3 has Counteract in them and I see no difference in the balance at any of my speeds.
Old Aug 2, 2015 | 10:00 PM
edk136's Avatar
edk136
Thanks for the reply, I'm leaning towards trying these
Eric
Old Aug 3, 2015 | 07:14 AM
gungatim's Avatar
gungatim
Eric
no, I think anything over 10mph and they balance right out.
To Tire Balancing Beads
