350 trans on 76 coupe
Old Aug 2, 2015 | 08:21 PM
Moose 02 FB's Avatar
Moose 02 FB
Default 350 trans on 76 coupe
just picked up a 76 with 40,000 miles and dumped the trans fluid. How much should I add if I did the trans and filter change. waiting for a manual but just got the car last week. also doing all the calipers and the rusted on brake lines and the rubber lines while I'm there. the car has been sitting in a garage since 1985 so going thru alot of maintence items. anything else i should look for, just drained all the gas lubed all the bushing and stablizers (will replace soon)
Old Aug 2, 2015 | 08:40 PM
BKbroiler's Avatar
BKbroiler
Four quarts should get you close.
Old Aug 3, 2015 | 06:35 AM
Moose 02 FB
thanks I did not want to overfill
should have a manual this week just have to go to the offie to print
also going to flush the coolant with all the choices which would you guys recommend for a 76
Old Aug 3, 2015 | 08:29 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I add about 3 1/2 qts., get it to operating temp and then top if off as necessary.
To 350 trans on 76 coupe
