454, unstable idle when hot
So if your car is having this hot running issue, go straight to the exhaust bi pass circuit and plug it up. A new intake manifold gasket is what you will need. one that does NOT have the "cut outs" for the ports. Its the steel gasket that plugs the ports up. Easy Peesy Japaneesie.
Your change seems to confirm it's heat related, something on the top of the engine being heat sensitive. A posting from Faster Rat also appeared to indicate this was a problem.
You may have something there. I'm just a bit hesitant to change something which used to work without knowing why the change is needed.
Took the best Corvette shop in the city a few months to figure it out. When they took off the intake manifold the amount of carbonized and burnt oil stuck to the underside of the intake was dramatic. He took some picks to show me. It looked like a chocolate was stuck to the bottom of the intake. They had to chisel it away before sand blasting it clean. I found a pick on google that looks just like my build up. Its is the smoking gun.
On the way home from the shop yesterday it was 32 degrees and 85% humidity. I was stuck in traffic for almost a hour with out even a slight hick up. 100% problem solved. Check
Those small ports between the large intake ports are the exhaust cross over ports. You can see they cross over right under the carb. Supper heating that carb to high heaven. So hot in fact that is burns up the oil creating this large build up. I mean that's f'n hot right there boys. When you change the intake gasket the cut outs are not there. Or you can actually fill in the ports with a billet slug. The gasket is easier and cheaper. Just like Nike said, Just do it!
Still wondering why many others aren't complaining of the same issues unless most others already modified their cars, same change? Could be regional fuel formulations, problem is worse in some areas than others?
I'd like to try some fuel without ethanol, see if that makes any difference. I don't know if such fuel is available in CT.
another note: correlating low oil pressure with poor idle needs supporting data, you cannot just draw that conclusion. oil pressure tends to drop when warm, and vacuum leaks often only show up when the engine gets hot.
either way, the advice on checking ignition coil is sound. it's often said most carburetion issues are actually ignition issues, so put it on a scope and verify there is no ignition problems that are contributing to the problem, like hooking the coil up backwards, or bad ignition parts when they get hot, plug wires arcing when hot, that kind of thing...
They're being made in China so their lifespan is very short as compared to the original AC Delcos of years ago. I have had pretty good luck with Standard Blue Streak as long as you get the better grade (Standard sells them in two grades).
They all come with the special "thermally conductive" goop that is supposed to transfer heat to the distributor housing but I have noticed that goop will quickly harden when exposed to heat then fail to conduct heat. As an experiment several years ago I started using Permatex Ultra Black RTV to transfer the heat and so far its doing a great job because it never hardens.
Measured the voltage at coil and it was 11 volts at idle and dropping to 10 volts when reving...
Suspecting that previous owner did not change original resistor wiring when installing the HEI.
Will rewire this week and see what happens.
