72 Vette not starting help
but with the key in START do you get 12 volts on the purple wire on the starter solenoid?
If not, do you get 12 volts into and out of the NSS?
72 schematic:
http://www.vetteprojects.com/bmv/mis...tte%201972.pdf
interior lights came on, radio worked, but turn the key - dead as a dodo.
put meter across battery, 12.8v.
but no click or anything from starter.
took battery out, and went to the shop i bought it from just 2yrs ago.
they load tested it on the bench, and it's kaput internally.
mine was a side terminal battery like original.
he said they aren't strong inside as a top post setup.
have had a battery trickle charger on car whilst is storage,
but just when you want to go for a drive, nothing works...
72 schematic:
