What is piston slapping?
Old Aug 21, 2002 | 02:02 AM
Scudd's Avatar
Scudd
Default What is piston slapping?
Quick question what is piston slapping, and how bad is it $ wise to fix?
Old Aug 21, 2002 | 02:14 AM
kenincanada's Avatar
kenincanada
Default Re: What is piston slapping? (Scudd)
Re bore and new pistons {rebuild} :yesnod:
Old Aug 21, 2002 | 04:01 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
A piston "slap" is created when the skirt of the piston "smacks" the cylinder wall as the piston goes up/down. In other words, the piston wobbles within the bore of the cylinder. A mild piston slap often will "cure itself" as the engine warms up and things expand with heat. If you've got piston slap at running temperature, sounds like you're in for an engine rebuild. Did you check the compression? Chuck
To What is piston slapping?
