I have used "Jet" products in my F-Bodies from the past and they were quite good, hopefully the Hypertech is not the same and a better improvement over the "Jet" chip in this situation. Then again with you have a modified CFI, you probably would not see the same results as a totally stock one like myself.
I think the OP was just looking for a faster ECM, which again IMO is not needed unless the CFI has been modified like yourself and other members that have done so... Now if he intends to do some mods, then that is a different story, but on a totally stock CFI, I think the $$$ can be spent elsewhere for improvements. JMO
Al, did you ever contact the TB rebuilder and if so, how did it go???
Yes I've called several times and left messages but nothing?? I have since installed my bored TBs and are working great so far.
