Bench Bleeding with Silicone Fluid
Old Aug 12, 2015 | 09:43 PM
ctuinstra's Avatar
ctuinstra
Default Bench Bleeding with Silicone Fluid
You may have already read my other post about going to DOT5, but I wanted to cover another topic related to it.
I have spent the better part of a day trying to fully bleed out the MC with the DOT 5 fluid. It just keeps blowing small bubbles! I found if it pump and release slowly, about 3-4 seconds per stroke, it clears up and doesn't produce any bubbles. However if I pump any quicker say 1-2 seconds per stroke, bubble just start appearing in the clear lines! I can actually see bubble form in the middle of the clear hose! I thought at first they might be coming from the cheap plastic hose barb fittings, but I have tightened them and even tried Teflon tape to seal it up. I really don't think it's coming from the fittings.
How can you keep air out of the lines? Should I not be stroking so fast?!
If it is because of pumping and releasing, why would it not do it under normal quick braking?
Old Aug 13, 2015 | 10:46 AM
pws69's Avatar
pws69
A pressure bleeder will solve the air issues but if there are other problems (leaking pistons, etc), they will surface after you are done bleeding.
Old Aug 13, 2015 | 10:59 AM
gungatim's Avatar
gungatim
are you using the flimsy plastic screw in nipples and lines that come with the M/C to bench bleed? they often do not seal well and leak where they screw in...
Old Aug 13, 2015 | 02:16 PM
ignatz's Avatar
ignatz
This purports to be a batch of dot 5 in a vacuum chamber. No data provided whatsoever so you can think what you want
Old Aug 13, 2015 | 02:22 PM
gungatim's Avatar
gungatim
what exactly does a vacuum chamber have to do with a pressurized brake system? or bleeding a M/C? I don't get your post...
Old Aug 13, 2015 | 02:32 PM
ignatz's Avatar
ignatz
The implication is that any air that is in the fluid has an intrinsic vapor pressure and in a vacuum would "boil" out of the fluid. You know, like your blood would boil in space. Suggests that there is a lot of air in that container. The guy who uploaded the video is on Facebook and I suppose if somebody wanted to contact him to see exactly what he did .... I am kind of surprised there are no comments. I am not standing behind this video in any way, thought it was kind of interesting if it's really what it says it is.
I had a bad experience with Dot 5 but the last time I posted somebody told me I didn't know what I was doing so I gave up taking that path.
Old Aug 13, 2015 | 10:00 PM
ctuinstra's Avatar
ctuinstra
This is the point that I'm trying to make. It seemed to be when the fluid it under extreme vacuum, it would form air bubbles in the fluid. So if one were to press hard on the brake pedal and then quickly release it such as sliding your foot off the pedal and allowing it to snap back, this would cause a very short, strong vacuum in the MC and down the brake lines and develop bubbles in the lines. At the rate that I was stroking it, it wouldn't even have to be that quick of a release. I just can't see how bubbles will not form in the lines under normal use.
I'm hoping someone much wiser then me knows their stuff about this fluid and can tell me why all my thoughts are wrong.
Old Aug 13, 2015 | 11:21 PM
vette_jim's Avatar
vette_jim
I had the same exact results using dot 3/4 synthetic fluid, new MC from NAPA. Instructions said to pump very slowly, 3/4 to 1 inch strokes until pressure builds (plugs sent with MC) then slow 1/8 in. strokes. I used tubes off the MC bleeders first then the plugs. Took about 1 hr but eventually cleared up with a generous amount of tapping . When I stroked too quickly I saw tiny pools of foam being released . I agree that's not real world function. Don't know how its going to work out yet, I still have to bleed the system. .
Old Aug 16, 2015 | 05:46 PM
TWINRAY's Avatar
TWINRAY
I know you didn't ask but I wouldn't use Dot 5. Been there, done that. My. 02 FWIW.
Old Aug 16, 2015 | 06:18 PM
ctuinstra's Avatar
ctuinstra
Okay, now I'm asking. What were your experiences?
At this point I have dumped the DOT 5 out of the MC and washed it all up and dried it. I'm leaning heavily back towards DOT 3/4 to see if it bleeds better and doesn't create bubbles. I was really hoping DOT 5 would be the answer to not having to completely rebuild the brakes every 10-15 years.
Old Aug 16, 2015 | 06:57 PM
jb78L-82's Avatar
jb78L-82
I have the OEM master cylinder in my 78 along with 4 SS calipers installed in 1985...change the brakes fluid every 3-4 years with DOT 3/4 and have zero issues....30 years and counting. Change the brake fluid periodically on these cars and you will be much happier than most concerning C3 brake issues. You cannot have brake fluid in these cars for 10-12+ years and not change it which is what I suspect many C3 owners do.
Old Aug 16, 2015 | 07:03 PM
ctuinstra's Avatar
ctuinstra
I certainly don't disagree with you. Just stinks having to do it so often with so few miles. I have actually changed out the brake fluids before on my DD. Heck even the power steering fluid, that's something you don't see most people doing.
Old Aug 16, 2015 | 07:22 PM
jb78L-82's Avatar
jb78L-82
You and I are on the same page....I use a turkey baster to remove the PS fluid on my DD every year form the reservoirs on my Grand prix...14 years old now (175,000 miles) with no leaks from the PS pump or Rack and Pinion and the same on my 2008 Chrysler 300 (125,000 miles). There is no lifetime fluid on any car despite what the manufacturers will say...planned obsolesence.
Old Aug 16, 2015 | 07:38 PM
toobroketoretire's Avatar
toobroketoretire
Okay, have you ever watched the prop of a boat start spinning and creating bubbles. When fluid is suddenly put under a low pressure it boils which creates the bubbles. Boiling does NOT mean it reaches 212 degrees but rather indicates its changing from a liquid to a gas. Under a sudden low pressure ANY fluid will create bubbles but then those bubbles are almost instantly absorbed back into the fluid.
Here's another way to look at it. When you see bubbles form in liquid brake fluid you aren't looking at air but rather the absence of that brake fluid.
Old Aug 16, 2015 | 07:46 PM
ctuinstra's Avatar
ctuinstra
I can understand that, however after the suction was gone, the bubbles were still in the line and they pumped through on the next stroke. I guess I could see it if they immediately disappeared as soon as there was pressure in the line again.
I totally understand what you are saying. I'm just trying to wrap my head around this whole thing. And it one of those things that you get one chance of the entire system being completely clean. I don't want to have to take everything back off and apart to clean out fluid to change it back over. Just trying to make the right decision the first time.
Old Aug 16, 2015 | 08:23 PM
TWINRAY's Avatar
TWINRAY
You still have to bleed on a regular schedule using Silicone brake fluid. If not it will still cause calipers to leak and gunk up. I couldnt believe the crap that was there when i replaced seals on leaking calipers after using SBF. Water (condensation ) will "puddle" using Silicone BF instead of mixing with it using Dot 3/4. I flushed the Dot 5 and went back to 3/4. Needless to say it was a lot cheaper. The only good thing about Dot 5 is that it won't lift paint if split but you shouldn't get ANY brake fluid on fiberglass. Ideally bleed every 2 years. Just my experience.
Old Aug 16, 2015 | 08:38 PM
toobroketoretire
When I switched over to DOT 5 I took the calipers and master cylinder off and pulled them apart. Then I blew 150 psi of compressed air at them to remove as much of the old DOT as possible. I also blew the lines out to purge them too. After the thorough cleaning I put the new DOT 5 fluid in and bled the brakes as usual. That was about 3 years ago and so far all is well as far as I know. I don't think the DOT 5 will cause crud to form but rather will create crud when mixed with DOT 3 and I don't think that crud would be harmful at all other than looking bad.
But DOT 5 does require the new J-1401 hoses because it'll swell the OEM hoses completely shut within 3 months.
To Bench Bleeding with Silicone Fluid
Old Aug 17, 2015 | 08:28 AM
gungatim's Avatar
gungatim
The only problem with that logic is that it is a sealed system. there is no vacuum. if you release the brake pedal, the pressure releases. no way for a vacuum to form. if there was, the pistons would retract. letting off the pedal only allows the pressure to equalize, not create vacuum...we use a hydraulic system for brakes for a reason, if it formed bubbles, it completely defeats the purpose of a closed hydraulic system. that is why bleeding is important, to remove any air which compresses. and changing fluid is important, so as to not have moisture absorbed, which would not happen anyway under normal circumstances, as the M/C is closed and sealed at all times. you are not supposed to leave the cap off for this very reason. if you do, it's advised to suck out the fluid in the M/C and re-fill...
Old Aug 18, 2015 | 08:53 AM
toobroketoretire
When the brake pedal is suddenly released and retracts behind the tiny fill hole a small vacuum is momentarily formed between the master cylinder piston and the brake fluid. Just a little one and that tiny vacuum creates fizzies of brake fluid VAPOR.................not air. Then the fizzies get absorbed back into the brake fluid.
Old Aug 18, 2015 | 09:44 PM
lionelhutz's Avatar
lionelhutz
I highly doubt the spring in the master creates such a high vacuum it can boil the fluid. Especially when the master has cup seals that will just let fluid flow around them when forced to go backwards in the bore.
Regularly flushing the fluid is the answer to that one. Actually driving the car doesn't hurt either.
This is how I feel too. I'm just not drinking the kool-aid.
I found it seemed I never got rid of the air either. I'm supposed to tap all over the brake system with a little hammer and pressure bleed and go exxxxttttrrrrrreeeemmmmllllyyyyy ssssllloooowwwwlllllyyyy with that crap. No, I'd rather just use DOT4 and easily bleed the brakes without wasting time.
