Front brakes lockup easily
Old Aug 12, 2015 | 10:45 PM
anesthes's Avatar
anesthes
Default Front brakes lockup easily
So I have this '75 that was in storage for 22 years.
Anyway, both front calipers were blown and leaking. I changed the master, the front calipers, and bled all 4.
Mind you i've never driven the car..
In my long driveway, if I get it rolling 5+ mph and hit the brakes hard the front lock up and leave 3-4 feet of rubber.
Now, I'm assuming this simply means the rear are weak and I should replace those calipers too.
Or do these cars have an absurd bias to the front?
-- Joe
Old Aug 12, 2015 | 10:56 PM
anesthes's Avatar
anesthes
Disregard.. I just looked at a picture on autozone of the calipers and realized there is TWO bleeders on the rear.
Holy crap! How I didn't notice that on the car..
-- Joe
Old Aug 13, 2015 | 12:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Most of the braking effort on C3s is at the front. The rears contribute, but the majority of the whoa is up front.
Old Aug 13, 2015 | 01:08 PM
hugie82's Avatar
hugie82
The proportioning valve is stuck. Try moving the rear Pistons back in the calipers and then slowly press the brake pedal to bleed the rear.
Old Aug 13, 2015 | 02:52 PM
Peterbuilt's Avatar
Peterbuilt
Default That was an easy fix!
-- Joe
Bleed the inners first then the outters.
To Front brakes lockup easily
