Vortek Heads on L48
Old Aug 14, 2015 | 03:18 PM
nivensid's Avatar
nivensid
Default Vortek Heads on L48
My 78 has the original L48 engine with the cylinder heads, Eldebrock Performer Intake side mount headers. If I install some Vortek heads to improve on the performance I'm aware I will have to change the intake manifold. Will the headers for the original heads bolt up to the Vortek heads? If not can someone suggest some heads that will bolt up to the headers? This is a weekend driver mostly, just looking for some better performance with better free flowing heads.
Old Aug 14, 2015 | 03:47 PM
tfi racing's Avatar
tfi racing
Unless you're getting the Vortec heads for free and having someone do a valve job,machining for better springs and rockers also for free,there are likely better aftermarket choices in either steel or aluminum...
Old Aug 14, 2015 | 03:50 PM
Zorro O's Avatar
Zorro O
I can't say for sure if these are the same, but I have a L31R crate engine in my 79 it came with Vortec heads. When I needed headers and could not get a straight answer from anybody on header fit, I bought the cheapest pair of Summit block hugger headers they had for a SBC. They bolted right up and have worked fine for over two years now. I do not know if all Vortec heads are the same, but calling summit might be a place to start.
Zorro.
Old Aug 14, 2015 | 03:52 PM
jim-81's Avatar
jim-81
Summit has a set of Vortec heads that have higher lift, and yes the exhaust will fit up. I did this and the heads are great. I was on a low budget so they were a great option. I think they were $339 each. I also put in a XE268 Comp cam and it woke it up big time. I did a thread on this. The Vortec heads are good and cheap - not the greatest but a good value.
Here are the Summit heads: http://www.summitracing.com/parts/su...make/chevrolet
Old Aug 14, 2015 | 05:21 PM
mikep3's Avatar
mikep3
I went with a Vortec heads via a kit from SD Parts it had bolts, gaskets, intake, rocker arms. I needed to buy push rods, valve covers and spark plugs. The L48 heads needed 400 to rework old smog heads.
The heads raise the carb so you need a drop base air cleaner and the exhausts ports are higher, not sure but .75" sounds right, it was not a problem
Looking back, I should have looked for cast iron heads with 64 cc chambers, like Brodie with .500 lift springs, Edlelbrock intake and made the engine bay look stock. But I was novice engine guy who wanted a kit.
Old Aug 14, 2015 | 08:08 PM
'75's Avatar
'75
I use the vortec heads, got them for $100 with the rockers, bolts and intake bolts. Heads were like new. Sidemount headers bolt right up, no problem. Really woke up the L48.
Old Aug 14, 2015 | 08:21 PM
wilcar's Avatar
wilcar
Look at the summit/dart large valve iron heads #152123 for $630. Have a set on my carbed C4, nice heads for the money.
Old Aug 14, 2015 | 10:37 PM
REELAV8R's Avatar
REELAV8R
How was your high rpm performance with those heads. Did they stop making power early on? Just wondering how the 165 cc intake runner performed. Ever get it dyno'd?
Old Aug 15, 2015 | 08:40 AM
nivensid's Avatar
nivensid
Thanks for all the replies, I am leaning towards the Dart 15213 heads so I can keep my Performer Intake. Now I need to match it to a cam that will give improvement from off idle to about 5000 rpm. Most of my driving is on weekends taking short trips to town and occasional trips less than 100 miles. 350 automatic 3:08 gears and stock converter. Any suggestions on the cam with these heads ?
Old Aug 15, 2015 | 08:42 AM
nivensid's Avatar
nivensid
Really need to improve the low end torque if possible with the 3:08 gears.
Old Aug 15, 2015 | 11:33 AM
96 lt-4's Avatar
96 lt-4
The comp XE262 or similar Lunati Voodoo grind should work well.Many others as well.Keep the gross duration around 260 and you will be fine with 3.08 gears.
Between the heads,increase in compression,and a better cam it will give it some PUNCH.Don't forget to curve the distributor if you haven't already.
Old Aug 15, 2015 | 12:04 PM
BKbroiler's Avatar
BKbroiler
Just to answer your original question - Vortec heads use the same exhaust manifold/header configuration as the stock heads.
Old Aug 15, 2015 | 12:32 PM
augiedoggy's Avatar
augiedoggy
voodoo 262 cam here with older dart iron eagle heads which perform similarly to the vortecs, they work fine with my 308 gears and auto trans.
I have 64cc heads with flat top pistons and a small .34-35 quench though.
Old Aug 15, 2015 | 12:39 PM
REELAV8R's Avatar
REELAV8R
I'm betting this cam would do well with those Dart heads.
http://www.lunatipower.com/Product.aspx?id=2324
Have a few here who have this cam and are pleased with it.
Old Aug 15, 2015 | 04:46 PM
augiedoggy's Avatar
augiedoggy
That is the very voodoo 262 cam I used... It had the best numbers by far than all the other cams that were similarly sized in the dyno 2000 program I used With all the rest of the info from my components punched in it stated an optimistic 396hp (at 5,500 rpm) and 414lbs of torque with 371lbs being available at 2,000 rpm...
it also brought my dynamic compression down enough to where I can run 91 octane gas with the iron heads.
I am using 1.6 rockers and an rpm clone intake to squeeze out as much possible power as possible on a budget.
BTW, I know those numbers are higher than what it likely really puts out. For some reason the flow numbers from the heads just workedwell with the cam I chose and the software showed a nice bump in power of the others I tried in the simulation including the comp lineup.
Old Aug 15, 2015 | 08:03 PM
wilcar's Avatar
wilcar
I rarely go over 5000 rpm but with the Isky 228-228 solid cam on a 108 lsa I have awsome low and midrange power. Using a Zz4 intake with a 600 Edel. No dyno testing but the 152123 heads are certainly a big improvement over the crappy 624 heads they replaced !! For $630 they are a real bargain in my opinion.
Old Aug 16, 2015 | 10:03 PM
MN80Vette's Avatar
MN80Vette
Default Vortec heads require Vortec-compatible intake
I have Vortec heads on my GM Performance 350 HO and it performs quite well. If you find a good deal on some Vortec heads (junk yards usually have them) and you're looking for a Vortec intake, let me know. I'm ready to sell my GM low-profile Vortec intake in the C3 Parts section. It fits under a stock '80 hood with a 3" filter on a drop base.
To Vortek Heads on L48
Old Aug 17, 2015 | 08:28 AM
ts_vette_st's Avatar
ts_vette_st
Anyone ever do the vortec head and intake swap and make a cowl induction air cleaner work?
Old Aug 17, 2015 | 10:09 PM
augiedoggy's Avatar
augiedoggy
I dont see why it wouldnt with a drop base air cleaner..
Old Aug 18, 2015 | 03:39 PM
ts_vette_st
Do you mean modify the stock base to be drop base so the cowl seal on the top half will be the correct height?
