Cable?
Old Aug 16, 2015 | 03:22 PM
Big Block 69's Avatar
Big Block 69
Default Cable?
On my 69, there is a short cable that runs from one side of the driveshaft tunnel through a loop on the rearend crossmember to the other side of the driveshaft tunnel. Could someone please tell me what this is or does?
Thank You,
Rick
Old Aug 16, 2015 | 03:23 PM
ddawson's Avatar
ddawson
Sounds like part of the parking brake cable. The long cable connects to this and pulls on each side of the parking brake.
Old Aug 16, 2015 | 03:30 PM
DonnieP73's Avatar
DonnieP73
That is a safety cable to the center seat belt mounting plates.
Donnie
Old Aug 16, 2015 | 04:33 PM
toobroketoretire's Avatar
toobroketoretire
That cable prevents your seats (and you if you're buckled up) from flying thru the windshield in the event of a 100 mph head on collision.
Old Aug 16, 2015 | 07:40 PM
SB64's Avatar
SB64
Default Cable
Donnies picture is a good illustration and hopefully yours are connected the same way otherwise you defiantly have a serious safety issue. Good picture Donnie!
R
Old Aug 16, 2015 | 07:57 PM
DonnieP73's Avatar
DonnieP73
R
Thanks Roger,
Just happen to have that one in my restoration photos.
Donnie
Old Aug 17, 2015 | 06:11 AM
Big Block 69
Default Cable?
Thank You fellas. I am changing to a solid axle and this was in the way. I will make sure it gets hooked back up.
again, Thank You
Rick
Old Aug 17, 2015 | 07:40 AM
Big2Bird's Avatar
Big2Bird
If you get in a 100MPH head on collision in one of these, that cable will help them find your body.
To Cable?
