Using Soluble Oil In Cooling Systems
Old Aug 20, 2015 | 08:11 AM
toobroketoretire's Avatar
toobroketoretire
Default Using Soluble Oil In Cooling Systems
I have used soluble oil in my cooling systems ever since the late 1960's when I was building engines for a living. The commercial radiator shop I was dealing with recommended it as did Caterpillar and Cummins because it drastically reduces the "cavitation erosion" that destroys the cylinder liners in turbocharged diesel engines. You have heard it referred to as a "water wetter" when its simply soluble oil that breaks water molecules apart (like any detergent will do). The hard deposits that form on the discharge ends of brass radiator tubes is the result of the lead solder being exposed to hot antifreeze and soluble oil prevents those hard deposits from forming; keeping the cooling system rust-free and clean. Soluble oil is available in pints, quarts, and gallons and isn't very expensive. The standard mixing ratio is one ounce per gallon so a little goes a long way.
Do any of you also use soluble oil in your C3's?
Old Aug 20, 2015 | 11:13 AM
gungatim's Avatar
gungatim
I do not, since modern anti-freeze already includes that. I do know people that would buy the lube/rejuvenator (same thing) and add to old antifreeze and recharge it though...
Old Aug 20, 2015 | 02:06 PM
tracdogg2's Avatar
tracdogg2
A lot has changed in the past 50 years.
Old Aug 21, 2015 | 10:58 AM
toobroketoretire
As copper/brass radiators using lead solder and antifreeze are still being used in a lot of vehicles the problem of hard deposits forming on the discharge ends of the radiator tubes still exists. If soluble oil is used from the beginning those deposits won't form.
Back in the 1950's when 180 degree thermostats were common the problem of hard deposits forming wasn't much of an issue. But once the use of 195 and 205 degree thermostats and 2-tube radiators began being used the problem suddenly became a BIG problem as radiators were plugging in as little as 2 years.
Its the increased heat that causes the chemical reaction between the lead in radiators and antifreeze that forms the hard deposits.
Old Aug 21, 2015 | 02:06 PM
gungatim's Avatar
gungatim
lead solder hasn't been used in years. ROHS compliance is the law. I doubt there's all that many original radiators still in use this long that haven't been re-cored or replaced...
Old Aug 22, 2015 | 11:46 AM
Gale Banks 80''s Avatar
Gale Banks 80'
I work in the marine industry. We used to use Soluble Oil in our Cooling systems. We don't anymore. We switched to other products in the 80's and 90's one of which was called NowCool. When we did we got Rust out of our systems we never even knew we had. Most modern engine manufactures have a specific blend of coolant to maintain any warranty. Caterpillar even make there own coolant. Its not an additive but the entire mix all made up. It is available in 5 Gal Buckets 50 Gal Drums or 300 Gal Containers.
Old Aug 23, 2015 | 09:50 AM
toobroketoretire
I wasn't aware of that. If lead-based solder isn't being use any more what alloy has replaced it?
Old Aug 23, 2015 | 10:51 AM
'75's Avatar
'75
Cat ELC, Extended Life Coolant, also available in gallons. Also has available Extender, to be added at 6000 hr intervals when testing requires to renew the additives.
Old Aug 23, 2015 | 10:52 AM
diehrd's Avatar
diehrd
Ask your EPA / Government .. Lead is highly restricted
Old Aug 23, 2015 | 02:44 PM
gungatim's Avatar
gungatim
tin, antimony, silver...
Old Aug 23, 2015 | 09:37 PM
Gale Banks 80'
One of our Engines holds 400 Gals Jacket Water and 1600 gals on the Intercooler side. We have 3 of these Engines. I guess I should of known that it came in 1 Gal jugs, we could form a bucket brigade.
To Using Soluble Oil In Cooling Systems
