Radiator arrived
Of coarse he can tell just by looking at it.
Did you read the first post.
“Keep in mind I am a 42 year Aviation guy and an FAA Inspector so I think I have an eye for quality. “
Anyone worth their salt dealing with aircraft parts better know what they are looking at.
At least to know, it is not what it should or could be and to know the difference.
“Really? What characteristics does the higher quality aluminum display that the cheaper aluminum lacks?”
[EDIT--- removed comment]
A DeWitts radiator screams at you it is a well thought out, well made quality product.
It has formed tanks, formed inlet and outlet, and is configured for your application.
It fits in the stock brackets and uses the stock hoses.
If you painted it black, no one without a magnet would notice it was not stock except for the beautifully welded tank seam.
And yes it cost more than a lesser product.
A Champion looks like it was made to the lowest price.
2 sizes fit all applications.
It has folded square cornered tanks.
Cut and welded sharp turn inlet and outlet.
Welds that look like they came out of a caulking gun.
Does not fit into the stock brackets without modification.
May or may not clear the hood.
May or may not use the same hoses.
And yes it cost less, but you got exactly what you have not paid for.
I was told it would take up to 10 days to build with the upgrade then shipped.
Ordered the custom build radiator on 8/10, shipped on 8/14 and received on 8/19. That was great service.
I look at the radiator and compared the quality to the Champions. Keep in mind I am a 42 year Aviation guy and an FAA Inspector so I think I have an eye for quality.
I find the quality in DeWitts craftsmanship and Aluminum to be superior to the Champion. The aluminum in the Champion appears softer than the DeWitts. I have purchased 3 Champions (2 for other applications) and with exception to the one I damaged no problem with them.
Again, however, now that I have seen the Champions quality next to the DeWitts; the DeWitts, technically and materially, is far more superior.
I am simply a satisfied customer that can see the difference.
I enjoy having the option to choose a better product instead of settling for the cheapest and many times only inferior option.
Formed tanks are harder to make, require expensive tooling and cost more.
Formed inlets and outlets are harder to make, require expensive tooling and cost more.
Proper welds require good welders that cost more.
Proper furnace brazed cores are stronger, last longer and cost more.
It also comes with customer service and quality control that cost more.
It is made in the USA that cost more.
This is why it is a better product that cost more.
The DeWitts radiator does fit in the stock brackets with the stock rubber cushions.
Mine has done so for many years.
It did so without modification, any extra effort or the purchase of new parts to connect it up.
The fact that they chose to make the tooling, to make a better fitting cushion, is one more example of what makes a better product.
And yes they have the audacity to charge a reasonable price for it.
Last edited by vettebuyer6369; Jun 17, 2016 at 11:02 AM. Reason: remove namecalling
Many people here simply choose for their own personal reasons to buy the less expensive champion , but in this case since all the cats here who run champion say it cools just fine that makes it inferior?
I guess it's inferior in ways other than doing what an aftermarket radiator does, "cools the vehicle"
Before you flame me...I not only have a dewitts but it was custom and cost even more....
Last edited by vettebuyer6369; Jun 17, 2016 at 11:04 AM. Reason: removed quote, beginning of argument
Quotation marks have a meaning and purpose.
I just make the stuff he may or may not have inspected.
With an experienced eye he noticed a difference based on observed facts.
[insult removed].
Many people can easily tell the difference between the widely available commercial alloys of aluminum and their heat treatment.
Aluminum is made to the same specification by all manufacturers.
If you want the specs look them up and learn what they mean.
I listed a number of facts that are the obvious observable differences between the two different radiators and formed my opinion.
[more EDIT, insults removed]
Last edited by vettebuyer6369; Jun 17, 2016 at 11:20 AM. Reason: personal remarks edited out
But, more important, when people join the forum and ask basic questions, I don't have a problem trying to help because this is a forum that is all about helping each other across all skill levels.
Seriously guys... That what this conversation reminds me of... (coincidence the most expensive toilet is a "C3"
) unlike the toilet... a person driving the car would likely not notice any difference in performance and function and most will not actually see and difference in longevity if cared for the same way.As far as composition, Isnt a fiberglass c3 heavier and "softer than a cheaper safer steel bodied car or even the newer corvette? Did this impact our decision to buy one? Why is it such a big deal here then? its not likely that a rock is going to hit a c3 raditator and even if it did it wouldnt be with any force at the angle it would come in at... has the softer metal been shown to wear out quickly with the right coolant?
Attachment 48362478
That's a Shepherd radiator that was around $170 shipped a few years back. 3-row aluminum radiator that is frequently found available on amazon, still for under $200 shipped.
BTW please don't pick apart my original fan mounting brackets and fuel line routing. I've addressed all that, these photos are several years old.
https://www.amazon.com/gp/product/B001CIEJRO
The pan covers basically all the radiator none is left out less being partially wasted,
When at highway speeds does the fan ever turn off....
I'm very pleased with the performance.
Really? The same pan? Was it because of one of my posts in the past or did you come up with it the same way I did? I'd love to see pics of that!
https://www.corvetteforum.com/forums...post1591952230
When it comes to the champion vs dewitts thing though it is a bit different... your are comparing two drastically different products one from the US that overbuilt if anything to one that made out of the country and made to cool an engine at normal radiator prices you would see for most other comparable tasks... Its also like comparing a factory valve cover to an expensive custom cnced polished one... My 40+ year old cheaply made harrison radiator was not built to the standards of the dewitts 43 years ago and it still worked ok 2 years ago when I removed it so...To me the Question of whether its logically worth it is in the eye of the beholder and can make sense if origin is important or a person is looking to rebuild and engineer the car to much higher standards than originally designed for looks as well as function. BTW harrison radiator is owned by GM /dephi now and I was told it cost somewhere between 30 and $40 to make most of their radiators ten years ago by a friend that worked there. just something to chew on.
My champion is hands down a better looking and functioning rad than the original It replaced and it was well under $200... Sure the dewitts might look better just as a set of $1200-1500 welded rims may be better than the $600 cast ones I just bought but would I ever need the advantages of the high end welded wheel? No just as I would guess a good portion wouldnt see benefits from a radiator that has a superior finish and spec tolerances. If someone wants one great but I really dont see the need for people to keep insisting they are the only correct choice for everyone and the other are junk... These cars weren't exactly known for their high end quality fit and finish so there's a lot of other things that could benefit more from the funds for me..
Last edited by vettebuyer6369; Jun 17, 2016 at 11:29 AM. Reason: removed deleted quote initiating conflict
