Verifying Holley Jet Sizes
Old Aug 21, 2015 | 01:49 PM
toobroketoretire's Avatar
toobroketoretire
Default Verifying Holley Jet Sizes
A few days ago I was checking some of my Holley jets and discovered several that weren't stamped correctly; #70s that were actually #72's, #72's that were actually #74's, and #74's that were actually #76's. Before screwing in Holley jets I recommend you verify their actual sizes by measuring them with number drills.
Old Aug 21, 2015 | 02:39 PM
BOOT77's Avatar
BOOT77
The hole length is another factor for Holley jets, resistance and size. Email or call them
Old Aug 21, 2015 | 02:47 PM
pws69's Avatar
pws69
People drill jets all the time. Unless I KNOW a Jet's origin, I will opt for a brand new one.
Old Aug 21, 2015 | 02:55 PM
BOOT77's Avatar
BOOT77
Think I read jets are not drilled and shouldn't be, it'll mess up the chamfer. Forgot to mention chamfer also effects flow. Bleeds can be drilled.
Old Aug 21, 2015 | 03:02 PM
pws69's Avatar
pws69
Shoudn't is correct - but from experience, Bubba rules on this one! That's why I always opt for new if there is ANY question.
Old Aug 21, 2015 | 03:08 PM
dochorsepower's Avatar
dochorsepower
It seems to me that I read somewhere long ago that the jet numbers were just numbers and not a dimensional size.
Old Aug 21, 2015 | 03:24 PM
pws69's Avatar
pws69
Each Number corresponds to a specific dimension
Old Aug 21, 2015 | 05:41 PM
toobroketoretire
These jets are new but they got stamped wrong and that's why I'm alerting you about this. Mistakes can and do get made.
Old Aug 22, 2015 | 10:07 AM
dzhrp7's Avatar
dzhrp7
Holley categorizes jets by flow, not actual jet size. The chart shown is reference info and indicates the nominal size typically associated with jets in the specific numbered category. However, entrance condition, orifice finish, length, exit condition, and specific size within the tolerance can influence the actual flow a jet will produce. That's why they flow them and then stamp the number.
Re-sorting jets by measuring with drills has a higher probability of error than Holley marking the jets incorrectly.
Old Aug 22, 2015 | 11:26 AM
cagotzmann's Avatar
cagotzmann
When I was tuning my engine the numbers didn't mean as much to me as the AFR reading I was getting. Reading plugs etc.
Once I got the AFR range and proper color on the plugs I was good to go. The numbers are useful only to know what AFR I got with the specific numbered jets.
Old Aug 22, 2015 | 11:33 AM
Big2Bird's Avatar
Big2Bird
Confession?
To Verifying Holley Jet Sizes
