I have always filled my car up with 92 octane fuel from Chevron. But I have considered that I may not need to. What was my engine originally designed to run on? It is a stock 454/270 hp, 8.5:1 compression, 113 cc open chamber iron heads, and is in good mechanical shape. Base timing is 11-12 deg at idle, with 36 deg at 2800 rpm.
Also, what exactly does 'knocking' sound like? I never heard it before, and I realize it is hard to describe in words. An example: a hammer hitting an anvil maybe?
IMHO, you could get away with mid-grade 89 octane, but I wouldn't go to the 87 regular. 8.5 really isn't high compression and was designed for lower octane and unleaded fuels. You will know knocking (pre-detonation) when you hear it. Most likely to hear it under load, accelerating lightly up a grade. Best way I can describe it is like a can with a small bunch of pebbles would sound like when you shake it. But you will know if and when you hear it. If you do, just switch back to higher octane. Also if your car diesels when you shut it off, could be indication it needs the juice :yesnod: Other posts have addressed this and one had a link to a chemists website which was very informative. :cheers:
I have always used lowest octane I could without knocking... Thus far with compression ratio of less than 9.0 I have always been able to use 87 with no problem. You waste money using octane higher than needed to prevent detonation. You WILL know when you get knock. :cheers:
I am using 92 most of the time and once in awhile 91 if that is all that is available, but I have somehere around 10.5:1 compression. Since it runs on this I see no point in putting 94 or higher in. My previous engine was 9.5:1 and it ran fine on 89 but knocked on 87.
With your compression you should be ok with 87. Our CDN 87 is a little better than US 87. If you have never heard pre-ignition you are a lucky boy as it is very noticeable and good ears will hear it every time. My 350 has 9.6 CR and can get by with mid grade although I use 92.
bob
