400 Turbo
Old Aug 21, 2002 | 09:45 PM
1979vett550hp's Avatar
1979vett550hp
Cruising
Default 400 Turbo
Can a 400 turbo transmission fit under a 1979 corvette, or would u have to change the mounts? I hurd that they came with a 340 turbo. Any help would be greatly appreciate. :yesnod:
Old Aug 21, 2002 | 09:56 PM
Jvette73's Avatar
Jvette73
Default Re: 400 Turbo (1979vett550hp)
you said 340 turbo..did you mean350? anyway..the two trannys should fit where the other one was provided the correct measures are taken
Old Aug 21, 2002 | 09:59 PM
Jvette73's Avatar
Jvette73
Default Re: 400 Turbo (Jvette73)
different driveshaft yoke
different overall length
different bellhousing to rear mount length
different kick down set up
thats about it...i think
Old Aug 21, 2002 | 10:08 PM
1979vett550hp
Cruising
thanks Jvette73 that is alot of help. Any more comments pleazz post the more help the better :yesnod:
Old Aug 21, 2002 | 10:13 PM
Jvette73's Avatar
Jvette73
If yur gonna switch from a th350...you might wanna consider a 200R4 or a 700R4. Lower 1st + overdrive to boot. Move it outa the past and more to the future. Change the car for the better.
To 400 Turbo
By Michael S. Palmer | 2026-05-22 12:13:46
