Air Conditionor noise
Old Aug 25, 2015 | 08:24 AM
news2me's Avatar
news2me
Default Air Conditionor noise
My A/C compressor on my '77, is making a noise. With just the engine running its fine, no noise at all. But once I turn on the A/C, the compressor is making a squealing sound, like a bearing is bad.... Is the compressor low on oil, is the clutch shot or a bad bearing... Do I need to replace the whole compressor or can it be rebuilt... Like I said, its fine with just with the engine running, but once I turn on the A/C I get the noise..
Old Aug 25, 2015 | 08:34 AM
Big2Bird's Avatar
Big2Bird
Originally Posted by news2me
My A/C compressor is making a noise. With just the engine running its fine, no noise at all. But once I turn on the A/C, the compressor is making a squealing sound, like a bearing is bad.... Is the compressor low on oil, is the clutch shot or a bad bearing... Do I need to replace the whole compressor or can it be rebuilt... Like I said, its fine with just with the engine running, but once I turn on the A/C I get the noise..
I would do something before you get metal shavings in the system.
Old Aug 25, 2015 | 08:57 AM
toobroketoretire's Avatar
toobroketoretire
Are you sure its not a loose belt causing the squealing?
Old Aug 25, 2015 | 10:40 AM
news2me's Avatar
news2me
Wouldn't a loose belt, make noise all the time. With or without the A/C being on. As long as the engine is running, that belt is turning...
Old Aug 25, 2015 | 10:53 AM
REELAV8R's Avatar
REELAV8R
No, it might not. belt might be tight enough just to run around the pulley but once you put a load on it, then it may squeak. A belt squeak should be familiar to you if you've ever heard one before.
Otherwise you have a problem with the clutch or a bearing in the A/C compressor. do you smell hot brake like smell? That would indicate a slipping clutch.
Old Aug 25, 2015 | 11:34 AM
news2me's Avatar
news2me
No, its not the belt, I know a belt sound. Its coming from the compressor. Its more a bearing, sounds like a water pump does when its going bad...
Old Aug 25, 2015 | 11:50 AM
REELAV8R's Avatar
REELAV8R
Kind of a rattling grinding sound? That sounds like the clutch assembly to me. Just a guess without actually hearing it.
Old Aug 25, 2015 | 04:42 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Try placing an auto stethoscope on and around the compressor to pinpoint the noise with the a/c on. I wouldn't continue to run it until you identify the problem.
To Air Conditionor noise
