Where is the courtesy lamp delay box????
Old Aug 21, 2002 | 10:50 PM
greggv's Avatar
greggv
2nd Gear
Default Where is the courtesy lamp delay box????
Can anyone tell me where the control that holds the courtesy lamps on after the lights are turned off is located? Thanx in advance! Gregg :rolleyes:
Old Aug 21, 2002 | 11:32 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Where is the courtesy lamp delay box???? (greggv)
I think its that orange box hanging on the passenger side under the windshield.
Old Aug 22, 2002 | 12:39 AM
tangee-vette's Avatar
tangee-vette
If it's a 77' the timer is taped, yes taped, to the wiring harness at the steering column.
Old Aug 22, 2002 | 01:14 AM
A C's Avatar
A C
Cruise-In II Veteran
Default Re: Where is the courtesy lamp delay box???? (tangee-vette)
There's a timer? :confused:
AC
Old Aug 22, 2002 | 11:01 AM
Woodstoc's Avatar
Woodstoc
In the 82, it is located behind th glove box. You have to remove it to be able to get to it. Orange in color. Check your door switches carefully before buying this expensive little monster.
Old Aug 22, 2002 | 11:34 AM
Bobchad's Avatar
Bobchad
and gets hotter than hades if you leave the door open for any length of time.
Old Aug 22, 2002 | 02:19 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Where is the courtesy lamp delay box???? (Bobchad)
The C4 delay timer can be plugged into the harness too (if you have the orange one, I know for a fact that one is used from 78-82). The little clip that secures it in place is on the wrong side for the C4 one but if you force it in it works. The layout of the edge connector is exactly the same.
78-82 model:
84-89 model: (according to artscorvetteparts, mine is black& different. Don't think the white one is correct, probably one that fits from another vehicle or so)
Mine: (this is a C4 one)
The 78-82 model is 45$ or so from artscorvetteparts, the 84-89 one around 23$. Quick profit there!
[Modified by Twinnie, 12:21 PM 8/22/2002]
Old Aug 22, 2002 | 06:51 PM
Paul L's Avatar
Paul L
This may help.
http://temp.corvetteforum.net/c3/pau...rlight_003.jpg
[Modified by paul79, 6:22 PM 8/22/2002]
Old Aug 22, 2002 | 06:55 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Are they adjustable? mine stays on a lot longer that I care for
To Where is the courtesy lamp delay box????
