cam specs
Old Aug 27, 2015 | 07:49 AM
57chevyeddie's Avatar
57chevyeddie
3rd Gear
Default cam specs
I have a 30 year old 1979 350 CI engine. The cam specs were not provided at the time it was built. I was told "it's a 350 HP, Corvette cam". Where could I get more in formation about the cam specs. I'm trying to buy a stall converter for this engine/trans combo. Thanks in advance.
Old Aug 27, 2015 | 10:56 AM
REELAV8R's Avatar
REELAV8R
What kind of vacuum are you pulling at 800 rpm? What can you idle down to in gear? That would give us an idea of the cam specs.
FWIW I installed a 2200 stall converter on my stock L-48 and it worked great. It actually stalled at 2400 instead of the advertised 2200 but worked well in any case.
Also good mod is a shift kit. Makes the shifts a lot faster and firmer.
Old Aug 27, 2015 | 12:07 PM
MelWff's Avatar
MelWff
There was a 327 CID engine with 350 HP, L79, and a 350 CID engine with 350 HP, L46, they did not use the same cam. This link has the specs.
http://www.superchevy.com/how-to/eng...-dyno-testing/
To cam specs
