79 Diff gears
Old Aug 22, 2002 | 10:30 AM
andyglines's Avatar
andyglines
5th Gear
Default 79 Diff gears
My dad has a 79 that he has done a little work to add some power. He wants to go with a lower ratio in the rear end. How do I find out what the current ratio is? Will any GM gears fit into the carrier or do they have to be from Vette.
Old Aug 22, 2002 | 11:10 AM
page62's Avatar
page62
Default Re: 79 Diff gears (andyglines)
You check it mathematically on Smokemup.com
I thought of doing this. Then I discovered that long-term I was better off putting the money into a 4-speed automatic instead.,
Old Aug 22, 2002 | 11:37 AM
Gordonm's Avatar
Gordonm
Default Re: 79 Diff gears (page62)
There are numbers stamped into the rear carrier but if the y have been changed you are out of luck. Jack the car up and mark the tire and drive shaft. Have someone rotate the tire exactly one turn. Count the number of times the driveshaft goes around. if it goes around 3 times you have a 3.08, 3 1/4 times 3.36, 3 1/2 times 3.55,3 3/4 times a 3.70 4 times a 4.10 and so on. This is the easiest and most reliable way aside from taking it apart and counting the teeth.
Old Aug 22, 2002 | 12:20 PM
andyglines's Avatar
andyglines
5th Gear
He's actually done more than a little work to it. Its got a 400 sb with a B&M supercharger. It has been tubbed and has some pretty big meats. He just put the Th400 in because he smoked the 700R4. The gearing is now a little to high he wants 4.10 or 4.56 now. Will any GM gears fit in the Vette diff?
Old Aug 22, 2002 | 12:45 PM
Gordonm's Avatar
Gordonm
No they have to be gears for the Vette. They won't fit anything else but the Vette. If he is going to run a 4.11 or 4.56 he is either going to have to use a 4 series carrier or special gears that fit on a 3 series carrier. The ones that fit a 3 series are thicker to compensate for the smaller pinion gear. If he wants a 4 series carrier I have a good used one for sale. I had a 4.11 gear with a spacer (not the thing to do) and was going to install the 4 series carrier. I blew the rear before I put in the 4 series and went to 3.70 gears. Let me know if interested
To 79 Diff gears
