suggestions
Old Aug 31, 2015 | 10:30 AM
upnorth's Avatar
upnorth
Default suggestions
best way to go , I want
both trailing arms full assembly maybe not rotors
studs for arms
strut rods and bushings
rear end bushings
strut rod cam assembly
rear shock bolts shim kit
crossbar bushings
rear spring steel or composite don't know which one .
have a guy ready to put it all together .
where would you think would be the best deal on all this ?
jacked it up . pass side a little play drivers side quit a bit , now that I have the engine running well I afraid I am going to rip everything out of the back end heard a pop the other day .
plus do they stock this stuff?
Old Aug 31, 2015 | 10:43 AM
Big2Bird's Avatar
Big2Bird
Originally Posted by upnorth
best way to go .........
Best as in best, or best as in cheapest?
Old Aug 31, 2015 | 10:54 AM
upnorth's Avatar
upnorth
reason able . ive seen trailing arms from 520 to 1000 each both with life time warranties .
Old Aug 31, 2015 | 11:01 AM
Big2Bird's Avatar
Big2Bird
PM sent
To suggestions
