79 bounce?
Old Sep 5, 2015 | 05:40 PM
Carpet's Avatar
Carpet
Default 79 bounce?
Hello,
I purchased a 79 that has been sitting since 99 with the original tires still on it. While taking it for a ride the drive train is very noisy along with a bouncing feeling as we were going down the street. I know the tires should be changed but what else can cause this feeling that's coming from the rear.
Old Sep 5, 2015 | 05:53 PM
COOLTED's Avatar
COOLTED
There are a lot of things that can do that. Until you get tires, about all you can do is give it a good visual. I am having a similar issue right now (although it doesn't sound as severe as your situation) and until I know the tires are good, I can't really do any real diagnosis.
Old Sep 5, 2015 | 06:45 PM
Carpet's Avatar
Carpet
Default possible bad spidle
I just rotated the tire and notice the brake rotor is running way out causing the pad pin to move in and out, I think the spindle may be bent. Anyone ever had a bent spindle?
Old Sep 5, 2015 | 06:55 PM
SH-60B's Avatar
SH-60B
The spindle doesn't rotate, you probably couldn't even tell if it was bent. The bearings are bad/loose, or there's some kind of debris between the rotor and the hub if the rivets are no longer in them, or the rotor is out of true. I wouldn't drive it with tires that old.
Old Sep 5, 2015 | 08:39 PM
lionelhutz's Avatar
lionelhutz
I suppose the rear spindle could be bent but more likely is a bad bearings.
Are the rotors still riveted onto the spindle?
Old Sep 5, 2015 | 10:26 PM
mac79vette's Avatar
mac79vette
I agree with not driving it on old tires. I had tires that only had about 4000 miles on them and we're just a few months old before I stored the car for 4 years. Tires looked fine when I took it out but about ten miles of driving the right front tire came apart. I was lucky that there was no damage to the car. Also from what I understand the rear spindles are not forged like the front for 79 so it's easy to bend them and although my car went to 125,000 miles before I had a bearing problem I was told by vette brakes and van steel that the rear bearings usually have problems with a lot fewer miles than what my car had on it. I think the number was something like 80,000 miles. I have a friend that had a hop or bounce in the rear of his 1980 vette and it was a bent half shaft.
If the runout is so much that the roter is not turning I would suspect a bent spindle.
Old Sep 6, 2015 | 10:29 PM
Priya's Avatar
Priya
Bouncy feeling when driving is usually bad shocks.
Old Sep 7, 2015 | 08:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Sep 7, 2015 | 03:00 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Carpet
Hello,
You have a 36 year old car, with 36 year old tires, that hasn't moved in 16 years, and when you try to drive it, it "bounces"???
The tires are probably "square" by now. Replace them first, then we can discuss things like shocks, out of balance driveshafts/half shafts, etc, that might be part of the problem....
Old Sep 7, 2015 | 04:05 PM
Priya's Avatar
Priya
Not likely the tires. Flat spot on the tires makes a thumping sound, not a bouncy ride.
The shocks can be tested without replacing the tires first.
Old Sep 7, 2015 | 07:48 PM
DrVincennes's Avatar
DrVincennes
Hello,
My '72 did the same thing after I bought it. Had bouncy a rear end that was most noticeable at lower speeds. Everybody told me it was the shocks or rear spring. Turned out to the tires were out of balance. Got the tires balanced and the bounce was gone.
Old Sep 8, 2015 | 08:00 AM
leadfoot4's Avatar
leadfoot4
Really???
Old, dried out tires will NOT provide a proper or safe ride. They most likely are a large part of the problem, and have to be replaced anyway, so why jump ahead to replacing the shocks? Since the car has been sitting for SO long, the shocks haven't seen any motion, they might be OK, at least for the short term, whereas the tires won't be any good at all. Therefore, you replace the OBVIOUS bad parts FIRST, eliminate them from the equation, then trouble shoot from there.
In all honesty, the brake calipers are probably questionable too. I'd inspect/rebuild/replace them, before going after the shocks.....
Old Sep 8, 2015 | 12:11 PM
Priya's Avatar
Priya
I'm surprised you don't know that leadfoot. You go to each corner of the car, press it down and watch it rebound. If it comes up and stays the shocks are good, if it comes up and bounces the shocks are bad.
To 79 bounce?
