1971 LS5 Engine Recreation
Old Sep 8, 2015 | 08:44 AM
Vortecpro's Avatar
Vortecpro
Default 1971 LS5 Engine Recreation
I was contracted by a customer to build a mild 454 for his 68 Vette, I came across a 512 block 1970 vintage along with a set of 820 heads, there was a Vette pan pan also but it was just to rough to use. So i built a .030 454 with a cast crank, factory 3/8 rods with ARP bolts, Speedpro pistons, a mild hyd cam, came in around 9.3 compression, LS6 rocker arms, factory 1973 cast iron intake, Harold Bettes Q-Jet. I enjoy these stock type builds its a nice change. Excellent idle with lots of vacuum. I ended up with 462 HP @ 5600 RPM with 532 TQ @ 3500.
Old Sep 8, 2015 | 09:20 AM
gkull's Avatar
gkull
When I saw your title I went
Why would anybody want that low compression 365 hp pig, but with your higher compression and cam you made @ 50 -100 hp over stock depending on who you talk to.
The 365 might have actually been as much as 50 hp higher because of rating changes in the early 70's.
Last year I also rebuilt a Vettes 454 and I went to @10.0 c/r and I think that the final installed cam was h-flat in the 238/248 with headers and free flowing exhaust. 4 speed car. The owner wanted all forged and we also went internally balanced. It was a night and day difference from when I drove it to the shop to when we finished it
Old Sep 8, 2015 | 10:00 AM
mikem350's Avatar
mikem350
I'd say you built a real tire fryer there! Hope the customer has some bucks left for new rubber
Old Sep 8, 2015 | 05:59 PM
Kid Vette's Avatar
Kid Vette
Very cool! This engine is going into my buddy's '68; which was originally a Tuxedo Black over Medium Blue L-71. It's an L71!
Old Sep 8, 2015 | 10:27 PM
Vortecpro's Avatar
Vortecpro
I would say 1971 LS5 HP rating was 365 HP SAE. I can say 462 STP HP on my dyno means mid 11 sec ETs in a 3700 pound car, easy.
Old Sep 8, 2015 | 11:12 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Would be neat to have back to back tested the tripower agains tthe Q-jet.
Your buddy is going to be in for a nice surprise once he stuffs his foot in it.
Mark...you just keep knocking out the hits! Congratulations!
JIM
Old Sep 8, 2015 | 11:22 PM
Vortecpro's Avatar
Vortecpro
JIM
Thanks Jim!
Old Sep 8, 2015 | 11:53 PM
72ragtop's Avatar
72ragtop
Curious to what cam and what were specs of cam you used.
Old Sep 9, 2015 | 02:19 AM
gkull's Avatar
gkull
I'd also want to know what cam he used. because the customer is always right we ended up with this crane cam, but the ci was 468 with an over bore.
Performance usage, good mid and upper RPM torque
and HP, bracket racing; Heavy, Pro ET, Super ET, etc.,
auto trans w/3000+ converter, oval track; Street
Stock, Enduro, Hobby, etc., 3/8-1/2 mile,10.0 to 11.5
compression ratio advised.
Saturday Night Special 3000-
6600
134551* 236/246 110 .553 .571
Old Sep 9, 2015 | 03:07 AM
ajrothm's Avatar
ajrothm
Solid power from such a mild combo.... (basically stock components)
That's more then we were able to make with our stock appearing/resto 396(408)...10-1 comp, 237/245 hyd roller, square ports, 163 intake... And we had a ton of money in that motor.
No doubt, yours is making twice the HP per dollar. No doubt it will scoot in a C3 if the car is setup right. Customer should be very happy.
Old Sep 9, 2015 | 09:20 AM
Vortecpro's Avatar
Vortecpro
Alan, when I stated mid 11s, I was thinking in my Chevelle. The cam was a hyd flat tappet 228 @ .050 .530 @ the valve 114 lobe separation. I would also mention my dyno is running about 1 percent low at this time.
Old Sep 9, 2015 | 10:25 AM
jnb5101's Avatar
jnb5101
What are the exact specs (primary rods, jets, power piston spring, size of idle down tubes, secondary rods and hanger, any extra air bleeds and anything else you can find out) on the carb? Do you have a graph of the A/F ratio?
Old Sep 9, 2015 | 04:52 PM
BBCorv70's Avatar
BBCorv70
Was this the cam used in the LS5 or your Chevelle?
Old Sep 9, 2015 | 09:18 PM
Vortecpro's Avatar
Vortecpro
My air turbine doesn't fit on the Q-Jet, so we never dialed the carb in, the carb is highly modified, I didn't build the carb and have not opened it up so I can't answer your questions. I will ask the builder.
Old Sep 10, 2015 | 08:03 AM
Vortecpro's Avatar
Vortecpro
LS5 build.
Old Sep 11, 2015 | 02:23 PM
Kid Vette's Avatar
Kid Vette
Would be neat to have back to back tested the tripower against the Q-jet.
JIM
He's considering installing a tripower eventually. Anybody have a guess if performance will increase or not?
Old Sep 14, 2015 | 11:43 PM
wheatpj's Avatar
wheatpj
Those are big numbers, the engine looks great, very OEM appearing. The customer should be mighty happy with it.
I also choose Mark to build an engine for my 71. The engine will be replacing my numbers matching LS5, which is going into hibernation. It’s going to be a little hotter build that follows Mark’s 570hp recipe plus a roller cam. We’re going with a factory intake manifold and a Q-jet setup. It should look very similar to the LS5 that is coming out, but have monster torque and HP, can’t wait till it’s finished.
Take Care
Pat
Old Sep 16, 2015 | 10:52 PM
carbster09's Avatar
carbster09
Excellent numbers, I have more cam, ... some real nice head work, with a 489 and put out 511 hp. Must have had some real attention to detail!
Nice build!!
Old Oct 20, 2015 | 09:16 AM
c6silver's Avatar
c6silver
I would also like to know the specifics on the carb...
To 1971 LS5 Engine Recreation
