Temperature Sender install
Old Sep 10, 2015 | 05:21 PM
79rovette's Avatar
79rovette
Default Temperature Sender install
Hello all!
I just took it upon myself to buy new aluminum heads. However I have a temp sender from the old iron heads. As you may have guessed it they're a different size. So I decided to say the heck with it and get a whole temp sender unit with a gauge. The issue I'm now facing is how to route the probe and line through the firewall. Any suggestions?
Oh btw I have a 1979 Corvette
Old Sep 10, 2015 | 05:49 PM
speedreed8's Avatar
speedreed8
Try running it through grommet for speedometer cable
Wilcox has a sending unit that will fit I think. It's a turned down oem unit.
Old Sep 10, 2015 | 05:51 PM
79rovette's Avatar
79rovette
Speedo cable it is! I'll try that later tonight Speedreed!
Old Sep 11, 2015 | 10:27 AM
79rovette's Avatar
79rovette
All set, found the hole and it worked great. Thanks again!
To Temperature Sender install
