Usually when there's a leak you'll find oil residue in the area. I don't see any in your pic. I stay with R12 if at all possible. That's what the system is designed for and it's still readily available. Going with 134a does not always provide proper cooling.
You"ll be much happier to just replace the hose assembly and recharge with R12. The aftermarket ,vintage air etc. don't make a kit to fit later c3's. If you're handy or have a big wallet, there are changes that can be made to make the r134a perform, but your least expensive option for now is to stay with what you have.
Is that really a crack or something that got stuck onto the tubing? Looks a lot like a gasket goop of some kind.
Its really a crack. Photo doesnt show it all that well, but its fully cracked. The AC stopped working over a year ago, and I never got around to investigating, but popped the hood a few days ago and noticed the monster crack in the line.
Why should the dryer be replaced? Are they damaged somehow it exposed to the air?
Yes the drier portion of the filter-drier absorbs moisture. Exposed to the air it becomes saturated and can no longer remove moisture from the system and must be replaced.
Your new one will have caps over the ends, don't remove them until you are ready to install it.. Pick a dry day vs a humid day for the job to keep moisture absorption to a minimum if you have the option.
You don't have a drier, you have an accumulator.
The accumulator does two things:
1. Inside the accumulator is a desiccant bag, used to remove moisture from the system. Since yours has been open to atmosphere the desiccant is used up.
2. You have a R4 compressor that does not have an oil reservoir. It gets all lubrication from the oil circulating with the Freon. Inside the accumulator is an oil separator and metering orifice. The separator removes the oil from the Freon. The oil then falls to the bottom of the accumulator. The orifice at the bottom then meters the amount of oil going into the compressor. The orifice is very small. If it gets plugged by any trash in the system it will stop oil flow to the compressor and burn it up.
This is why they always insist you replace the accumulator when you buy a compressor.
Mike
Dryer should be replaced every time the system is open. As mentioned, it absorbs moisture (from the air), one of the enemys of a/c. It should be the last thing replaced and done so just before pump down. Good luck.
