Front control arm bushing sleeves.....guidance please?
Old Aug 22, 2002 | 09:17 PM
keith72's Avatar
keith72
Default Front control arm bushing sleeves.....guidance please?
I removed the rubber from the bushings of the lwr/upper control arms and left the outer shells installed. It appears that the outer shells have migrated out(?) and won't allow clearance for the shafts to be rem/inst.
Obviously, this could be an issue when reinstalling the bushings. I had hoped to use the existing shells and just press in new poly bushings.
Any help? (Hope the pics post right)
Old Aug 22, 2002 | 11:56 PM
Barry's70LT1's Avatar
Barry's70LT1
Default Re: Front control arm bushing sleeves.....guidance please? (keith72)
I don't understand what you mean. Can you provide a little more explanation.? I can't see any pics.
Checked your site, nothing on front suspension.
I don't believe you can remove the lower shaft with the shells in place.
Not sure about the top shaft.
I had hoped to use the existing shells and just press in new poly bushings. Any help? (Hope the pics post right)
Last year I intended to do the same. My shells were in perfect condition.
However, the poly bushings had a slightly less than snug fit in the original shells. They fit nice and snug in the new shells.
So, out came the old shells. A bit of a job, however you can do it without a press. You just need a large bench vise.
Old Aug 23, 2002 | 05:54 AM
keith72's Avatar
keith72
The sleeve flanges don't fit flush with the outside of the control arms. I'm not having any luck with pics it seems. If the pic doesn't post here, its on my homepage at
http://kksjjohnson.home.mindspring.c...sig%20pics.htm
Old Aug 23, 2002 | 06:07 AM
jackson's Avatar
jackson
Keith:
What you're experiencing is perfectly normal. I may have this wrong but I think the uppers will remove with some finangling. But unless there's something wrong with the shafts then you don't need to remove them. If shafts're OK then just drive a thin wedge in the split that's in the inner sleeve .. it'll then slide off. Then just press on the new inner sleeve ... and then slide on the new (poly I hope) bushing. I just did mine this way.
Old Aug 23, 2002 | 10:39 AM
john's '81 mouse's Avatar
john's '81 mouse
Yep, like others said, upper shaft will come out with the sleeves still installed, but the lower shaft will not come off unless you remove the sleeves. (Make sure you mark each shaft and re-install shaft in same control arm and same position as removed.) I installed new upper sleeves and kept my old lower sleeves when I installed my poly control arm bushings. (didn't have a press, and really didn't want to booger up the control arms, so after test fitting the new poly bushings in the old lower sleeves, and all seemed OK, that's the way I went.)
To Front control arm bushing sleeves.....guidance please?
