Fusible Link Question
Old Aug 23, 2002 | 12:25 PM
flynhi's Avatar
flynhi
Default Fusible Link Question
The engine bay harness in my 71 has two fusible links near the horn relay.
Does anyone know what gauge wire these links are? Or what they should be?
They are not called out on the wiring diagram.
Thanks.
Old Aug 23, 2002 | 12:35 PM
73ANGEL's Avatar
73ANGEL
Default Re: Fusible Link Question (flynhi)
I believe the rule is that you use a fusible link that is two wire sizes smaller than the wire your protecting.
i.e. use a 14 gauge fusible link to protect a 10 gauge wire.
Hope this helps.
Dale in Badgerland.
Old Aug 23, 2002 | 12:38 PM
sb69coupe's Avatar
sb69coupe
The links are most always one gauge smaller than the wire of the circuit itself. So for the 10 ga circuit, use a 12ga link, etc.
Old Aug 23, 2002 | 01:49 PM
Jester69Stingray's Avatar
Jester69Stingray
Default Re: Fusible Link Question (sb69coupe)
On my 69 there is a 12 ga wire with a 14ga fusible link shown on the wiring diagram.
Old Aug 23, 2002 | 03:26 PM
flynhi's Avatar
flynhi
ttt
Old Aug 23, 2002 | 03:56 PM
sb69coupe's Avatar
sb69coupe
I'm looking at the '71 wiring diagram in my Haynes manual. There are 2 wires off the horn relay that are shown with fusible links. The 12ga Red wire has a 16 ga black fusible link in it, and the 16 ga black/dark blue/white wire has a 20 ga orange fusible link. Looks like I was wrong about the size difference in my first post.......
Old Aug 26, 2002 | 01:02 AM
flynhi's Avatar
flynhi
Buried in my Chilton's is a table of fuses which lists:
Solenoid Bat Terminal - 14 ga fusible link
Horn Relay - 16ga fusible link
Voltage Regulator, no 3 term - 20 ga fusible link
Ammeter circuit (both sides of meter) - 20ga fusible link
72 appears to be the last year for fusible links.
To Fusible Link Question
