Correct speedometer cable length?
Old Sep 19, 2015 | 05:28 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Default Correct speedometer cable length?
Hello C-3 Forum:
What was the orig. length for a 1968 BB, 4speed speedo cable w/casing? it is 1 piece from Muncie to back of speedo head.
I see them offered from 61" through 81" ?
I have not pulled my old one off yet to measure it's oal.
Threaded knurled nut at transmission side of cable casing is stripped and will not tighten. It starts to tighten and slips loose again. Some gorilla grip in the past over tightened it with channel locks
Thank you,
Marshal
Old Sep 19, 2015 | 08:55 AM
toobroketoretire's Avatar
toobroketoretire
I would buy the longer 81" cable so it can be routed with larger bends.
Old Sep 19, 2015 | 05:39 PM
Gale Banks 80''s Avatar
Gale Banks 80'
The Cruise Control Cars use two Cables. One to the Firewall where the Cruise control was and then a Short one to the Speedo. A Car with out uses one long one to go all the way.
Old Sep 19, 2015 | 08:16 PM
marshal135's Avatar
marshal135
Gentleman Thanks for the replies.
81" seems a little long? Seems like there would be allot of cable
to route? I don't know as 61" maybe too short?
Anybody recently tackle this job on a 68/69?
Worse senario, I'll have to pull the old one out and get out the tape
measure.
When did cruise control become avail for c-3's?
Marshal
Old Sep 19, 2015 | 08:23 PM
69FASTFUN's Avatar
69FASTFUN
I replaced mine in my 69 and the length was 70"
Purchased from Paragon
3898
Speedometer Cable-SPEEDOMETER CABLE-70" LONG W/BLACK JACKET W/O CRUISE CONTROL
Old Sep 19, 2015 | 10:45 PM
marshal135's Avatar
marshal135
thanks 69FF.
That's what I was looking for.
Marshal
Old Sep 20, 2015 | 10:13 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Gale Banks 80'
...The Cruise Control Cars use two Cables...
True, but there was no factory cruise in 68.
Originally Posted by marshal135
...When did cruise control become avail for c-3's?...
77.
Old Sep 20, 2015 | 09:37 PM
marshal135's Avatar
marshal135
Thanks Mike
Marshal
Old Mar 5, 2021 | 07:15 PM
Wayne Calhoun's Avatar
Wayne Calhoun
1st Gear
measure.
Marshal
You'll need that extra length in order for it to reach
To Correct speedometer cable length?
