Best shocks for lowered c3
Old Sep 19, 2015 | 05:41 PM
Sam927's Avatar
Sam927
4th Gear
Default Best shocks for lowered c3
Hey all...bought a 74 coupe lowered 2" and shocks are kinda weak. Any replace rec?
Thanks!
Old Sep 19, 2015 | 06:00 PM
briankeery's Avatar
briankeery
What rear spring is installed in the car? That might make a difference in choice.
Old Sep 20, 2015 | 01:36 AM
Sam927's Avatar
Sam927
4th Gear
Not sure...I'll go through all the receipts I received with the car and advise. Appreciate your quick response, Brian!
Old Sep 20, 2015 | 11:46 AM
mikem350's Avatar
mikem350
At least report back if its steel or fiberglass. If steel how many leafs?
If glass, sometimes a part # is visable
Old Sep 20, 2015 | 11:16 PM
Sam927's Avatar
Sam927
4th Gear
Thanks!
I found paperwork that states "install rear spring cups with lowering bolts"...that's it. Leafs have a couple spots I can see a very small amount of surface rust so I'm assuming they're steel. 6 leafs.
Old Sep 21, 2015 | 12:03 AM
couperdecar's Avatar
couperdecar
Bilstein. I'd do it again in a second.
Old Sep 21, 2015 | 12:35 AM
Sam927's Avatar
Sam927
4th Gear
Thank you! Think edelbrock shocks are on it now. Only about 3k miles (I'm told) on them but 10 years old.
Old Aug 17, 2016 | 02:00 PM
DJmaya's Avatar
DJmaya
I know this is old but I just replaced my rear shocks on my 77 and I am incredibly satisfied with the change and I replaced Bilsteins
I had Bilsteins Sports on my rear with the single leaf composite. One of the bilsteins gave up and the car sat uneven with one side lower than the other. I never really liked how much the car bounced on certain parts of the highway so I was on the hunt for stiffer shocks and the guessing game of what I am going to like
Then I found the QA1 single adjustable shocks and was amazed at how much better my ride became. The adjustable part is literally a *** I can turn with my hand with 18 settings and all i have to do is reach behind the tire and turn. No more guessing before purchase at how stiff you should go and then regret it.
I am not even halfway to the stiffest and the ride is already firmer than the Bilstein sports without being harsh. The car drives like a dream.
Even better they sell the shocks at different lengths so you can adjust your ride height AND there is also a dual adjustable shock if you are interested on doing gritty track tuning.
Old Aug 17, 2016 | 08:55 PM
silvvette's Avatar
silvvette
bilstein hd, all day!
Old Aug 18, 2016 | 11:52 AM
Tim Ware's Avatar
Tim Ware
Switched my 71 big block with 360 composite to Bilsteins & thought I went to heaven. Not only in ride, but better control of the rebound. My head doesn't hit the roof anymore !
I'm a Bilsteins believer. Tim
Old Aug 18, 2016 | 11:57 AM
Team Lazy's Avatar
Team Lazy
18 settings = 17 chances to get it wrong
Old racing saying...
Old Aug 19, 2016 | 10:45 AM
AirBusPilot's Avatar
AirBusPilot
I have the adjustable QA-1's.
Van Steel told me which settings to use, and they work perfect.
But, yeah, just guessing if you don't know what you're doing won't work.
Old Aug 19, 2016 | 11:26 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I have the non-adujstable QA1's. Gives a very nice ride.
Old Aug 19, 2016 | 11:52 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Bilstein
Old Aug 19, 2016 | 11:56 AM
gkull's Avatar
gkull
The question from the poster was the best. Bilstein is a middle contender and it would be a downgrade. As shocks go. AC-Delco, KYb gas adjust, Bilstein, Koni, QA-1 single adjust, then on top is the QA1 dual adjust.
Adjustability is the key. Koni is the first in that line up with 3 way adjust. I personally use QA-1 dual adjust coil over shocks for ride height ability on the front and QA-1 dual adjust with a custom rear mono spring rear.
Since you are new (maybe?) to vettes. The rear spring end bolt length is how you adjust the rear height.
http://www.zip-corvette.com/68-82-c3...a1-shocks.html
Old Aug 19, 2016 | 12:43 PM
gkull's Avatar
gkull
This is kind of my front setup. speed direct sells the springs for $50 a set or so and they come in 50# increments. I would get the 550# even for a small block. I use 600, 650, and 700 pound fronts.
See if speed direct has this kit also.
https://www.corvettemods.com/C2-C3-C...s_p_14089.html
To Best shocks for lowered c3
