76 Shift Linkage set up
Old Sep 20, 2015 | 03:07 PM
Greg Delfino's Avatar
Greg Delfino
Cruising
Default 76 Shift Linkage set up
I replace the clutch on my 76 Vette and I am now having difficulty correctly setting up the shift linkage. The interlock linkage is too short for me to connect and still remove the key from the ignition.
Is there a tool that I need to set up the neutral position on the shifter?
Thank you in advance for your assistance in this matter.
Greg
Old Sep 20, 2015 | 03:24 PM
oledave60's Avatar
oledave60
You didn't say, so I assumed a stock shifter. Here is instruction for a 75. I think it will be the same.
Old Sep 21, 2015 | 09:44 PM
hwcoop's Avatar
hwcoop
here are the dimensions to make the shifter adjustment tool
and where to place it
To 76 Shift Linkage set up
