New Heads and Cam!!
Old Aug 23, 2002 | 02:57 PM
72Shark's Avatar
72Shark
Default New Heads and Cam!!
Hey guys, got the news today....my Birthday Present is my choice of new heads and cam!!! I'm thinking Trick Flow's (64 CC) with a Comp Cam 270 Magnum, anybody running similar?? ....Or your advice......appreciated.
My setup: '72 Coupe, 4-speed, 3:36 rear. 4-bolt, steel crank, dynomax headers, duals, MSD Billet distributor, performer intake, Q-Jet (tweaked!), power brakes, A/C.
Old Aug 23, 2002 | 03:31 PM
Alwyn678's Avatar
Alwyn678
Default Re: New Heads and Cam!! (72Shark)
Sounds nice to me
Old Aug 23, 2002 | 07:23 PM
terryrudy's Avatar
terryrudy
I like the aluminum Trick Flows I have on mine. I went with cc 268h cam and its a definite improvement over stock while retaining a relatively mild idle. Its the first cam I tried.
-terry
Old Aug 23, 2002 | 08:42 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: New Heads and Cam!! (terryrudy)
270 H is a great cam lots of low down torque, great for the street
I pulled 340 ft/lbs at the rear wheels on a chassis dyno, not bad for a mouse:D
[Modified by MotorHead, 6:45 PM 8/23/2002]
Old Aug 23, 2002 | 09:02 PM
tnt76vette's Avatar
tnt76vette
Default Re: New Heads and Cam!! (MotorHead)
Sounds like a winner to me......BTW will you PLEEZ tell whoever is doin' the buyin' that MY birthday is September 18th? THANX :jester :jester :jester
Old Aug 24, 2002 | 11:48 PM
72Shark's Avatar
72Shark
Default Re: New Heads and Cam!! (tnt76vette)
Wifey doin' the $$$.....yep...got a good one. BTW, she likes the way my vette looks, but she really likes that picture of MotorHeads vette. Thinks your car looks "pretty", a compliment I'm sure.
Anyhoo....Trick Flows with 1.26" springs (.500 lift max) or 1.47" springs (.540 lift max).???? 270 Magnum advertises .470 gross lift, and I'm using 1.5 ratio roller rockers. Shouldn't the 1.26" springs do the job????? Would save a little for extras!! :p:
Old Aug 25, 2002 | 01:06 AM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
I'd pop fo the 1.47's. Besides giving you "room to grow" if you want a bigger cam or 1.6 rockers later, the larger springs are less likely to have a problem controlling the valves at high rpm even with your present cam/rocker combination. I don't know what spring TrickFlow (Summit) uses but most head mgs also use a higher quality spring when going from their "economy: model.
To New Heads and Cam!!
