zz350
Old Sep 24, 2015 | 05:28 PM
ugly85chevy's Avatar
ugly85chevy
Default zz350
I know my mind is jumping ahead about 2 years, but in a fit of boredom I checked craigslist for engines and found someone selling a zz 350 for $3500... about 1/2 the new price. Would that work in a 79?
Here is the link in case anyone in MI is interested.
http://annarbor.craigslist.org/pts/5208293744.html
Old Sep 24, 2015 | 10:02 PM
cobrachuck's Avatar
cobrachuck
Yes it will work, is your car auto or stick?
Also check Jeg,s & Summit to compare to new
Old Sep 25, 2015 | 10:04 AM
ugly85chevy
I have an auto. How do I identify the transmission? I am a couple years from being ready for a new engine but I was surprised at the number of engines for sale locally. I'll need some time to figure out what engine would suit my needs best and I will have to get this thing on the road to figure that out.
Old Sep 25, 2015 | 01:25 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Wow the 3500 is what I paid In 2004 for my new Zz4.
Old Sep 25, 2015 | 07:42 PM
Shark Racer's Avatar
Shark Racer
That doesn't look like the intake that came with the ZZ4 - depending on what's on there and what you have, you may need to change the intake or your carburetor to match.
Old Sep 26, 2015 | 01:17 AM
chevygod's Avatar
chevygod
This motor looks like a ZZ crate 350, which I think had a square bore intake, not a ZZ3 or ZZ4, which were spread bore. If so, first of the ZZ motors, so maybe pre-1996 or 1997? I got a deal on a ZZ3 at about that time, so if this is a "ZZ350", it may be the plain "ZZ" which is the earlier one. Still cool but maybe not at this price. Also, looks run hard.
Old Sep 26, 2015 | 08:16 AM
derekderek's Avatar
derekderek
I believe that will be the one piece seal engine. Change over was 30 years ago, but to c3 guys that is late model stuff. Would need different flywheel.
Old Sep 26, 2015 | 01:17 PM
Shark Racer
Got it. I automatically ASSumed it wsa a ZZ4. But yeah, if it's a square bore like you say an dhe's running a QJ, he'll need to get a different intake, carb, or adapter. The adapter, of course, will likely require a drop base air cleaner or a different hood.
Myself, if I had a QJ I'd switch to the ZZ4 intake or Edel 3701.
Old Sep 26, 2015 | 02:11 PM
ugly85chevy
Thanks for all the replies. I know I'm a long way out from doing a swap but should I start keeping my eyes out now for something and if so what should I be looking for? Ok, yeah that was a pretty open ended question. I'll keep reading, learning and looking.
Old Sep 26, 2015 | 02:19 PM
derekderek's Avatar
derekderek
Ok, the piston tops down, the engines are pretty much the same. Yes, you can get forged crank-pistons and 4 bolt mains but if you aren't going to the track and turning 7000 rpm's that is not necessary. So if you don't need a rebuild, heads-cam-intake might be another option to consider.
Old Sep 26, 2015 | 03:05 PM
Sigforty's Avatar
Sigforty
The big advantage to the zz engines when new is a warranty and roller cam.
Old Sep 26, 2015 | 07:22 PM
TWINRAY's Avatar
TWINRAY
That's wayy to much money. Mine was 4200$ delivered 3 or 4 years ago. The used one has no warranty. No more ZZ4s. The base ZZ4 at 355 hp and 405 torque was a hell of a bargain . Not so with the ZZ5.
To zz350
