Brake question
Old Sep 25, 2015 | 08:46 PM
accuracymark's Avatar
accuracymark
Default Brake question
i have a 1980 that I have done a frame off resto on. The new brakes and calipers etc... on all four corners. The brake pedal was going soft and sometimes pull to the left on cold braking. So I bled and bled, then that only seemed to last a week and then back to the soft pedal. so I have finally this week have a a chance to really dig into it. I dial the front right and it had .011" runout. so Im in the process of truing that up. But I also noticed that the caliper was leaking a bit. I am wondering if the excessive runout caused the leak? or is it a separate issue? Should I rebuild the caliper? If anyone could advise that would be helpful.
brent
Old Sep 25, 2015 | 09:04 PM
Big2Bird's Avatar
Big2Bird
brent
Run out will make them suck air, but not leak.
Old Sep 25, 2015 | 09:06 PM
accuracymark
Better take the caliper apart and see what's going on.
To Brake question
