Custom gauge clusters
Old Aug 25, 2002 | 06:53 PM
  #41
Monty's Avatar
Monty
Default Re: Custom gauge clusters (Twinnie)
LOL! No is just took it out to allow easier removal of the tach/speedo housing, as well as access to wiring etc. I also had to run a -04 line for the boost gauge. It's only 4 bolts ,a set screw, and a couple of electrical connections, so it just makes life alot easier.
Old Aug 25, 2002 | 08:50 PM
  #42
Monty's Avatar
Monty
Default Re: Custom gauge clusters (Monty)
Here are 74droptop's pic's. Very nice install in an earlier C3.
Old Aug 25, 2002 | 11:11 PM
  #43
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I think your past the sleeper look. Excellent job. Do the console too. It look out of place now in black. :cheers:
Old Aug 25, 2002 | 11:37 PM
  #44
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Those look awesome. I would really like a set in carbon fiber for my 80, is that possible Monty?
Old Aug 26, 2002 | 03:40 AM
  #45
Turbo-Jet's Avatar
Turbo-Jet
Monty, that looks nice. You should look into getting those panels electro-polished and/or anodized. It would look great and be very durable, plus unique. Anodizing is very cool, and pretty inexpensive.
:cheers:
[Modified by Turbo-Jet, 11:45 PM 8/25/2002]
Old Aug 26, 2002 | 10:32 AM
  #46
vettedan's Avatar
vettedan
Monty- Great idea! I also went with Pro Comp Tach and speedo gauges. You got me thinking of modify my console more than I already have. Good job.
Dan
http://www.vetteworksonline.com/console_small.jpg
http://www.vetteworksonline.com/dash2_small.jpg
Old Aug 26, 2002 | 03:52 PM
  #47
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I think those panels engine turned would be very :cool: ...below is a link to a turned panel pic for comparison :cheers:
http://www.hanelineproducts.com/41-4...truck_zoom.jpg
[Modified by yellow 72, 2:53 PM 8/26/2002]
Old Aug 26, 2002 | 04:17 PM
  #48
Swamp Thang's Avatar
Swamp Thang
Very cool Monty - but I'm curious why you put the tach on the left, doesn't that make it harder to see when you have one hand on the shifter and the other on the wheel at 12 o'clock? 74droptop has the speedo/tach opposite yours.
Old Aug 26, 2002 | 04:21 PM
  #49
Monty's Avatar
Monty
Default Re: Custom gauge clusters (yellow 72)
Eastwood sells an "engine turning" kit, I don't know how well it works but the option is there if anyone's interested.
Old Aug 26, 2002 | 04:24 PM
  #50
Monty's Avatar
Monty
Default Re: Custom gauge clusters (Swamp Thang)
I just put it all together real quick to show to the guys that inquired about it. The other 6 gauges will be rearranged as well, I just put them in randomly. I have to pull them back apart to make templates for several guys that have emailed me wanting a set of panels.
[Modified by Monty, 2:25 PM 8/26/2002]
Old Aug 26, 2002 | 09:25 PM
  #51
tshort's Avatar
tshort
CI 7-8 Veteran
Monty, your craftsmanship is awesome. I normally like aluminum dashes, and your gauges look good in them too, but when I saw the pic with them installed in the interior my opinion is that you either need to also do the shifter console, or paint them black. It just doesn't seem to flow together. Just my opinion though. Either way, I'd just be happy to have your car!!!
:cheers:
Old Aug 26, 2002 | 09:42 PM
  #52
Frank75's Avatar
Frank75
Looks good, Monty.
