Heads upgrade for my 71 base model
Old Sep 30, 2015 | 02:39 PM
DONCZ's Avatar
DONCZ
Cruising
Default Heads upgrade for my 71 base model
So , I know this is repeat question .
I'm so confused with all internet search .
I wont to upgrade my engine to get 350+HP from it but would like to maintain original look .
What heads can I use and cam to combine with.
Old Sep 30, 2015 | 03:34 PM
hugie82's Avatar
hugie82
Dart iron eagle heads will get you close but aluminum is the way to go. You can go a point higher in compression and loose a few pounds in the process.
Old Sep 30, 2015 | 04:08 PM
DONCZ's Avatar
DONCZ
Cruising
Default Cast heads
I was considering 461 heads with accessory holes , any thoughts ?
Old Sep 30, 2015 | 04:14 PM
toobroketoretire's Avatar
toobroketoretire
Bear in mind an increase in horsepower will come at a higher rpm. The high horsepower factory cars all came with the lower gears necessary to maintain drive-ability so unless you are willing to go the whole route you'll end up with a high top end but lower performance down low where you really want it.
Old Sep 30, 2015 | 05:07 PM
DONCZ's Avatar
DONCZ
Cruising
Default Car set up
Im going to rebuild block as well. Had in mind 2004 stage 1 transmission and 3.73 rear end.
Old Sep 30, 2015 | 06:39 PM
jb78L-82's Avatar
jb78L-82
I rebuilt the engine in my stock L-82 4 speed car back in Spring 2014 and wanted to retain as much "L-82" as possible....unless you look closely, the engine looks like a stock L-82 with the aluminum heads the difference (not real noticeable). I bored the OEM numbers matching block .030, had the forged L-82 rods reconditioned, had the forged L-82 crank reconditioned, reused the OEM aluminum L-82 intake, air cleaner assembly etc. I did, however, put a set of AFR 180 65 CC aluminum heads on with a .015 head gasket (compression 10.2:1) AND a howards roller cam (219/225 duration, .525/.525 lift, LSA 110) with JE forged racing pistons (9:1). The engine has better bottom end than the OEM L-82 (much more), tremendous mid range power (2,500-4,500 RPM) and screams to 6,000 RPM-its simply a monster with better power everywhere than most SBC's. The engine idle is better than the L-82 and pulls seamlessly from 900 RPM in 4 th gear with no tractability issues at all. The new L-82 will simply smoke any SBC C3 from any year with an OEM Corvette engine..hands down. AND it runs perfectly fine on 89 octane fuel...Go aluminum heads with a roller cam....just pick the right cam for what your are looking for and don't go crazy with lift and duration.
To Heads upgrade for my 71 base model
