Power window problem
Old Oct 7, 2015 | 04:45 PM
76l48stingray's Avatar
76l48stingray
1st Gear
Default Power window problem
Power windows stopped working after an accidental arc while changing fuses. I replaced the breaker in the fuse block and the relay. Getting power to the relay, but not the switches. Any ideas?
Old Oct 7, 2015 | 07:11 PM
hugie82's Avatar
hugie82
Doesn't the window switch power the relay?
Old Oct 7, 2015 | 08:53 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Use this and you'll find your issue.
Willcox
Old Oct 8, 2015 | 01:55 AM
gmachinz's Avatar
gmachinz
Did you make sure to mount the relay back to a metal source? The negative side of the coil inside the factory relay gets its ground through the relay housing itself.
To Power window problem
