AC blower high speed
Old Oct 17, 2015 | 05:33 PM
pepegriffo's Avatar
pepegriffo
Default AC blower high speed
AC high speed not working. seems like I have med. speed, one speed. I had some issues wrong wires set into both the relay and resister connectors. That has been solved with a lot of forum help, thanks to all who responded. .
Orange connector on relay no power. I jumped from the red connector to the Org. conn. Blower high speed kicked on. Did a continuity test, from the org. conn on the switch to the org conn on the relay. Have continuity. But no pwere.
Any thoughts would be appreciated. This has been a bugger.
Old Oct 17, 2015 | 10:05 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I'd look real hard at the switch.
Old Oct 17, 2015 | 10:07 PM
0Willcox Corvette
Former Vendor
The blower switch is what switches the power from yellow to orange... Here is a video on how to test it.
Blower Switch Testing 77-82
Old Oct 18, 2015 | 11:02 AM
pepegriffo's Avatar
pepegriffo
Thanks I will pull the switch.
Old Oct 18, 2015 | 04:04 PM
pepegriffo's Avatar
pepegriffo
Well, I pulled the switch, it tested good. Pushed on the connector for the heater control, wala high speed came on, wire in connector was loose. Now to put it back together again. It would be nice if I was rubber man.
I want to thank all the members who responded to my call for help. every step suggested got me to the fix. Agaiin thanks to all.
Old Oct 18, 2015 | 07:57 PM
0Willcox Corvette
Former Vendor
Good deal, glad you got it fixed.
Old Oct 18, 2015 | 11:12 PM
pepegriffo's Avatar
pepegriffo
Thanks for all your help.
To AC blower high speed
