Question...?
Old Oct 22, 2015 | 08:02 AM
labhound's Avatar
labhound
Default Question...?
Can solid roller lifters be used on a hydraulic roller cam?, it's a garage debate, I'm sure they can but for how long...?
Old Oct 22, 2015 | 08:26 AM
toobroketoretire's Avatar
toobroketoretire
I would think they could be used IF the rocker arms had a small amount of lash to prevent valve burning. But without gentle clearance ramps the lash would cause the valves to "hammer" open so I would think camshaft, push rods, and rocker arms would fail quickly. It would be like dumping the clutch every time you started off....................
Old Oct 22, 2015 | 08:57 AM
bashcraft's Avatar
bashcraft
I remember reading long ago that hydraulic lifters could be used on a solid lifter cam, but solid lifters can not be used on a hydraulic cam. A solid lifter cam has ramps that gently take up the clearance needed with solid lifters.
Old Oct 23, 2015 | 11:30 AM
bluedawg's Avatar
bluedawg
Fwiw and from were I heard it, I've heard that you could run solids on a hydraulic, but not hydraulics on a solid and the reasoning of this was the ramp rates of the solid would have hydraulics floating, on the solid lifters you'd still have to run lash.
Old Oct 23, 2015 | 06:52 PM
labhound's Avatar
labhound
A chicken before the egg type agreement....
To Question...?
