I am rebuilding my 1971 LT-1 engine which came originally with 9:1 cr (was probably more like 8.75 in reality). The engine builder due to worries about detonation and probably warranty says I should go no higher than 9:25 cr. It will be running solid lifters and the original 3972178 cam, iron heads, & 170 degree thermostat. Most of the people that I contacted (no names--don't want to drag them into this) have all said go 10:1 cr. Others have said 9:75:1. I would be running 93 octane pump gas. Curious if any of you with LT-1, Z28, or other higher compression motors have problems with detonation using pump gas in your cars. What is the max cr. Any suggestions/advice greatly appreciated.
are the heads being worked or all stock? The more efficient the head the better you will be running a higher cr. The cam profile also plays a role. Either way 10:1 on 93oct is doable all day long...been done....doing it right now. I run 11:6 in my car but I have good flowing aluminum heads and lots of cam which help me get away with it.
You should have no issues at all. I run pump gas in my C4 race car that has 11.3:1. It does have a lot of good things on it like a tight quench, small chamber aluminum heads, and good cooling, but at the factory '71 LT1 spec you should have no problems at all.
have a 70 Lt-1 short block with the original solid cam and early version of Chevy slant plug iron heads which have been surfaced at twice in the last 35 years 64cc chambers 93 octane gas.
Yes, at low rpm the cam will bleed off cylinder pressure but at high rpm when the pressure is at it's highest it'll overpower the octane's ability to resist detonation. Limit the compression ratio to 10.5 to 1 maximum and you'll barely get by.
I have 10-1 compression and pretty quick advance in the distributor with no issue. If you end up with some detonation you can back off on your timing a little. Truthfully I would be amazed if you had a problem.
Total timing is initial, cyntrifical, and vacum, I'm closer to 52 degrees.compression makes power, timing affects the way an engine performs. Less timing doesn't mean higher compression isn't worthwhile.
A true 10 to 1 is no problem with that cam. Use a Felpro 1094 gasket if your block is undecked and your pistons are stock compression height. Shoot for .040 quench, no less than .035.
First of all it is dumb to even run a stock solid cam. From 45+ years ago. They were made back when spring technology was poor.
I've rebuilt a few solid cam 70's Lt1's and went with the Crane solid.
I've always used flat top forged pistons with 1.6 ratio rockers. As cam duration goes up the dynamic compression ratio goes down. Read up on it.
I would find and engine builder than understands Chevy small blocks because I drive around today with a 11.2 on pump gas putting out in the mid 500's HP out of a small block and my other 434 small block is 11.7
I think the consensus is 10:1 CR is not a problem. The question of how high on premium 93 octane gas is still open for discussion. I don't think 10.25:1 or maybe even 10.5:1 seems to be a problem with those that responded. Above that depends on the car--whether it has aluminum heads, timing, cam, etc. Thanks to all those individuals who took time to respond to my question. I really appreciate it.
I personally do not like backing off of the timing because of how high the compression is. The previous version of the engine in my car was flat top 406 with .041" (I think) gasket and 58 cc l98 heads, unknown cam and could only do 32* of timing on 93. I currently have about 11:1 version of the same engine with 36* and the engine seems happier (if that makes sense).
I run a stock 72 LT-1 on 93 with no problem...also run my 68 Olds 442 with stock 10:5 to 1 on 93 with no issues....BUT they both love 112 octane racing gas from time to time.
Fred
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Because it is an iron head iron block engine and a 9.5cr for your '71 LT-1 you want to stay below at or below 10:1cr. I would not exceed 10:1cr with this combination regardless of cam duration. This way you know you are safe on premium gas and if you get stuck somewhere you could use a mid grade and get home.
The proof is in the pudding though, every engine is different. Your engine builder doesn't want your engine to have any problems so he plays it on the safe side.
I have a 600HP aluminum headed iron block with 10:6cr. Because I have all the tuning tools and gauges in my garage to make it run correctly I am able to run mid grade 91 octane in it.
You could probably do the same however the engine builder has no idea what knowledge or resources the customer ( you ) have he is always going to cover his ***. Stick to a CR below 10:1
