Next mod?
Old Aug 25, 2002 | 09:53 PM
ctc's74vette's Avatar
ctc's74vette
Navigator
Default Next mod?
I have headers, exhaust, intake, carb on my 74 350 and I want to know what my next mod should be right now i am running about a 15.0 1/4 mile need to break into mid 14's. Also if i go cam what size?
Old Aug 25, 2002 | 10:01 PM
QuickVet's Avatar
QuickVet
Default Re: Next mod? (ctc's74vette)
cam or gears. all depends on how much drivablilty you want to give up.
Old Aug 26, 2002 | 11:58 AM
Alwyn678's Avatar
Alwyn678
Default Re: Next mod? (QuickVet)
gears..........3:73 :yesnod:
Old Aug 26, 2002 | 10:09 PM
no_radio's Avatar
no_radio
Couple of questions....
L-48 or L-82?
Rear gear ratio?
4-speed or automatic?
I would suggest cam or heads if you have a 3.38 or (numerically) higher gear ratio, otherwise consider the gears. Also depends on the condition of the engine and rear end. If one or the other seems questionable start at that point.
Check my website to see what can be done with an L-48...running with the LS1s all day and very streetable.
Jeff
Old Aug 26, 2002 | 11:22 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I would change heads and cam.. Those are the mods that give you most horsepower in return..
:cheers:
Olivier
To Next mod?
