Starting problems
Old Oct 23, 2015 | 09:17 PM
Bill Jones's Avatar
Bill Jones
Default Starting problems
Sometimes when I get in my 1977 corvette and turn the key nothing happens. If I turn the key back and fourth it will start up. The starter is about a year old. Someone at the car show tonight said it may be the tumbler. This is a four speed car. Any suggestions? Thanks
Old Oct 23, 2015 | 10:51 PM
vbgod1's Avatar
vbgod1
Ok, I'll start...
Key turns, there is nothing wrong with the lock tumblers.
That leaves the starter, clutch start switch, ignition switch and wires. I would kinda rule out wires, as "jiggling" the key would not affect that. I would assume you keep the clutch pedal down as you jiggle, so it would either be making contact, or not. Ignition switch, or starter.
Get a test light and put the alligator clip, that you normally ground it with, on the small starter terminal, with a purple wire connected to it. The pointy end of the test light, that you normally look for power with, should be grounded to metal on the engine. Turn the key and watch the light. If it does not start, and the light lights up, it's the starter. If the light does not light up, you need to trace back and see where the connection was lost, ignition switch, clutch...
Old Oct 23, 2015 | 11:06 PM
vettz73's Avatar
vettz73
Also check the neutral safety switch.
To Starting problems
