Hello new member here rebuilding 76 want to put 427 in her will there b any problems other than different motor mounts on engine. I no I can't use the ones off the 350
A big block will drop right in with no problems other than the front springs will need to be changed because of the additional 250 pounds of weight. I ended up putting 1" aluminum spring spacers from Summit Racing under my new front springs to get the front end high enough to avoid tire/fender rubbing.
Have you considered a big inch small block or LS engine ?
You can do a 427 inch small block without the weight penalty.
