differential experts help me decide
Old Nov 1, 2015 | 10:36 AM
hamck's Avatar
hamck
Default differential experts help me decide
A few weeks ago, after a Sunday drive, I slowed down for a red light and heard a clanging sound . When I pulled out, I heard the same sound for a few feet, then it stopped and hasn't returned. It resembled the sound when you bang on the drive shaft with a wrench, a hollow ringing sound. I disconnected the half shafts and spun the wheels looking for any binding. Everything seemed smooth, u joints are good , brakes are good, yokes had about 1/8 in. of end play. So I turned my attention to the differential. When I drained the lube in the oil, I found a few fine particles. Some were black and soft, I assume was friction material , and some metal pieces one seemed to look like a tooth chip. I took a small tube and used a shop towel as a filter, and my shop vac to try to vac. any remaining pieces out of the case but didn't get any more. So I refilled it with oil. It took 8 oz shy of 2 quarts on refill. Does it hold 2 qts. exactly or do I have 8 oz. of yuck still in there? Now the hard part, should I run it or pull the diff. for a closer look. My head says pull it, but my back says run it and see if it gets any worse. Removal is a big deal when you have to work on a creeper on jack stands. As always, I appreciate any and all responses.
Old Nov 1, 2015 | 03:06 PM
centuryoldracer's Avatar
centuryoldracer
I have actually had the clutches chatter so bad pulling away from a sharp turn, that I thought someone lightly rear ended me. Try adding some GM limited slip additive, sometimes 2 bottles are required to stop the chatter. The stuff Ford sells works good also, just don't get it on your hands or they will stink for a week.
Old Nov 1, 2015 | 03:22 PM
gbvette62's Avatar
gbvette62
You need to use the GM limited slip (or posi) additive, to keep the rear end quite.
If your sure you cleaned the rear out sufficiently, ad the posi fluid and then find an empty parking lot, and do a number of figure eights and maybe a few clockwise and counter clockwise donuts.
Old Nov 1, 2015 | 03:36 PM
toobroketoretire's Avatar
toobroketoretire
Sounds like a good way to get arrested for a DUI. The factory never did any figure 8's and neither did the dealers so why do you feel its necessary? The need for figure 8's is an old myth that got started by ignorant fools.
Old Nov 1, 2015 | 03:51 PM
rebel542's Avatar
rebel542
Add me to the ignorant fools list. I've drove my 79 over 200K and always did the figure 8 thing after servicing the rear. Besides, whats it gonna hurt?
Old Nov 1, 2015 | 05:40 PM
hamck's Avatar
hamck
Thanks guys i was going straight when the noise appeared. Does the rear hold exactly 2 quarts if so i have 8 oz of crap left in there. I'm afraid a tooth chip got between the ring and pinion . What you think?
Old Nov 1, 2015 | 05:46 PM
hamck's Avatar
hamck
I've owned this car for 8 years and never heard this sound before.
Old Nov 1, 2015 | 07:31 PM
mortgageguy's Avatar
mortgageguy
Mine takes approx 1 1/2 qt plus 8 oz of LS. Some only use 4 oz. I don't believe you have 8 oz of gunk in there. You never said you put the LS in or not. You really should do that and take it for a test drive.
Old Nov 1, 2015 | 08:24 PM
hamck's Avatar
hamck
The gear oil i used had the additive already in it. I didn't have a chance to go for a spin yet. Better weather is coming up this week. I'll see then.
Old Nov 2, 2015 | 12:08 AM
centuryoldracer
It doesn't matter, you still need to add either the ford or gm limited slip additive or it will still chatter.
Old Nov 2, 2015 | 05:10 AM
Haggisbash's Avatar
Haggisbash
I was testing my transmission a while back and the requirement was to stand on the brakes and put the foot down on the accelerator to see if the transmission clutches were okay. Well the transmission held up but the diff made a funny noise the next time I drove the car. A few figure eights in a local car park and all was well again. I guess the posi clutches didn't appreciate the abuse from the test.
Old Nov 2, 2015 | 03:00 PM
COOLTED's Avatar
COOLTED
That's interesting because I just read a couple service manuals that say to do just that.
Old Nov 2, 2015 | 03:14 PM
MelWff's Avatar
MelWff
many years ago I did time trials and autocross. Heard a noise from the rear changed the fluid and added the additive. Ended up blowing the rear on the Long Island Expressway at speed. The ring bolts loosen, eventually one or more may fall out or have the head shear off.
Old Nov 3, 2015 | 11:44 AM
hamck's Avatar
hamck
ouch what did that cost? I was hoping for some wisdom from tracdog2 or gtr1999. I don't have any super duper motor, but I don't want to get stranded either. or worse bust the case from something getting between the gears.
Old Nov 3, 2015 | 11:52 AM
MelWff's Avatar
MelWff
installed a used 3.70 at the time for a couple of hundred bucks. Luckily had a friend with a trailer to flat tow the car. You have ruled out the parking brake?
Old Nov 3, 2015 | 12:26 PM
bashcraft's Avatar
bashcraft
No, it won't. I've changed rear end lube in mine at least 4 times in the last 36 years. Used the lube with the LS additive already in it and never needed anything else.
Old Nov 3, 2015 | 12:55 PM
sstopczy's Avatar
sstopczy
If you really want to see if it is still dirty in there drive it around and really let the new oil get warmed up and mixed in. Then pump and little out so you can see what it looks like. If it looks new, I'd say you got it all out, but if it is dirty I'd say you might need to take it apart.
To differential experts help me decide
Old Nov 3, 2015 | 06:42 PM
centuryoldracer
That is a good call on the parking brake. Kind of a pain to check though if the factory rivets are still holding the rotors on.
Old Nov 3, 2015 | 06:45 PM
centuryoldracer
Let me clarify that some never chatter no matter what you put in there, and some stubbornly chatter no matter what you put in there. So if you have the latter, then the additive will clear it up every time if the fluid does not.
Just trying to be helpful.
Old Nov 4, 2015 | 08:37 AM
hamck's Avatar
hamck
Thank you all for your responses. I never experienced differential chatter before so i don't know if thats what i heard or not. It hasn't done it since. It was a sound like the drive shaft was banging back and fourth. Like an 18 wheeler when pulling out on a hill. I don't want to do any damage to the case to the extent that it can't be rebuilt. I only have about 75000 miles on the car.
