Rear end drain plug
Old Nov 3, 2015 | 05:08 AM
stingraymax's Avatar
stingraymax
Default Rear end drain plug
I replaced the oil in my '75 rear end, cleaned the plug and threads but when I try to put in the plug I can't get it to go in completely I still have like 3mm of thread sticking out.
That doesn't seem normal is it ? There was no washer or gasket in between when I took it off.
Anything that I'm missing ??
Old Nov 3, 2015 | 05:42 AM
toobroketoretire's Avatar
toobroketoretire
The Corvettes use a 1/2"-NPT fill plug (a common pipe plug) with tapered threads and they're supposed to stick out a few threads. Pipe plugs just need to be tightened snugly.
Old Nov 3, 2015 | 06:43 AM
stingraymax
OK thank you, I'll give it an extra twist ;-)
To Rear end drain plug
