C3 Diff gearing for TH700
Old Nov 9, 2015 | 03:30 PM
Steve scott's Avatar
Steve scott
Cruising
Default C3 Diff gearing for TH700
Hi guys
I finally bit the bullet and sold my old engine ready for a 383 crate motor upgrade.
The 1st question is what diff ratio would you recommend for a th700 box, i need it snappy around town and good for weekend highway cruising. the diff in it now is a 3.08.
2nd question, is what torque converter would you recommend,brand,stall,lockup,and why.
im sure there is a early c3 out there with the same upgrades 383 450hp,th700 box with that perfect diff ratio and torque converter setup.
Thanks again i appreciate any advise.
Old Nov 9, 2015 | 03:37 PM
TedH's Avatar
TedH
Originally Posted by Steve scott
Hi guys
I have 3.54 gears and it is VERY snappy off the line with a mild converter; very close to stock stall.
Old Nov 9, 2015 | 03:45 PM
Bloodzone's Avatar
Bloodzone
I've researched that same question. Most will say 3.55 or 3.73
Old Nov 9, 2015 | 04:11 PM
gkull's Avatar
gkull
Just put a little thought into it. How did it drive in third gear with a 3.08? What RPM do you want to have with your tire diameter and normal freeway speeds. What is the max rpm of this new 383?. They have all kinds of rpm and mph online calculators.
i went through this same dilemma when I installed my 700R4. But I had an agenda of a top speed and the power to get there.
Just some math with a .70 OD 4th gear make these effective rear end gears
4.11X.70 = 2.877
3.90X.70 = 2.730
i opted for the 4.11 and drove it for 20 years. I always thought in retrospect that the 3.90 rear would have been a good choice on lower rpm motors. I had high rpm 383 and later i went to a somewhat lower rpm 427 small block.
I wanted to enter the Nevada silver state open road race, 93 miles of two lane highway. My class max allowed speed was 175 mph. My peak hp was right at 6300 rpm and I was using 27 inch tall goodyear racing tires. 4.11 put right at 175 mph and the ability to get up there as fast as possible. My 700R4 was modded for no kick down to run wide open throttle in 4th gear.
http://www.angelfire.com/fl/procrastination/rear.html
Old Nov 9, 2015 | 04:39 PM
toobroketoretire's Avatar
toobroketoretire
Hi guys
A set of 3.73's will give you a 2100 rpm @ 60 mph cruising speed.
Old Nov 9, 2015 | 05:27 PM
Steve scott
Cruising
It sounds like a seriously fun toy,
The previous setup was 261 hprw, TH700, 3.08 diff, 27 inch tyres.
In third gear it drove fine on the highway,in 4th gear it bogged down to 1900 RPM @ 60 MPH. Sluggish around town.
The new motor is 450 HP @ 5700 with tall 27 inch tyres.
The other issue is with a performance roller cam motor i've heard that you should keep the highway RPM around 2500 for lubrication.
I also read somewhere that the perfect all round diff ratio for a TH700 is 3.36 which sounds similar to a 3.08.
Old Nov 9, 2015 | 05:42 PM
Steve scott
Cruising
I'm starting to lean towards a 3.55,
I just have one chance to get that perfect street/ highway setup before my wife sees our credit card.
Old Nov 9, 2015 | 06:53 PM
Bloodzone's Avatar
Bloodzone
I have a factory 3.55 in mine and I'm happy with it. I would probably be just as happy if I had the 3.73. You can't go wrong with either. First gear is over fairly quick. Even more so with a 3.73
Old Nov 9, 2015 | 09:13 PM
tixeon's Avatar
tixeon
I have 3:55's and am happy with them. (383 roller cam motor.). I had a 2400 stall converter and got sick of it for normal driving. It was a pain in the *** trying to regulate speed in town in 3rd gear. I put a 1600 stall in and like it much better. Don't need much stall with the low first gear of a 700R4 combined with the torque of a roller cammed 383.
More stall would do nothing for me as I can liquefy the tires taking off from a stand still with out touching the brakes.
I don't understand the reason for keeping rpm's above 2500 on the highway. I've never heard this before.
Old Nov 9, 2015 | 10:01 PM
Steve scott
Cruising
I thought that between 2200 and 2500 rpm would be better for the engine on the highway, what highway rpm would you suggest.
Old Nov 9, 2015 | 10:08 PM
Steve scott
Cruising
I don't know if the angle, Your vet looks fantastic with the with that colour combo.
Old Nov 10, 2015 | 02:24 AM
Haggisbash's Avatar
Haggisbash
Look at the rpm of the later engines/cars at highway speeds to give you an idea but in my opinion the idea is not to run off the bottom of the cams rpm range at highway cruising speed so your gearing, cam and converter need to work together. I run a 200R4 with a 2.55 ratio giving me just over 1800 rpm at 60 mph (coincidentally almost exactly the same rpm as my Mondeo diesel (Ford Fusion to you). I use a 2100 rpm converter but I have lock up on fourth to stop slip at highway speeds. The cam is stock, if I was doing it again I would have used a stock converter because climbing the hills near where I live where the speed limit is 30 mph the slip of the converter does a fine job of turning fuel into heat instead of forward motion. I can lock it down into second to get around this but I don't think the neighbours like the roar of the engine
Old Nov 10, 2015 | 06:25 AM
tixeon's Avatar
tixeon
It's going to depend on your cam specs and driving style, but I don't think oiling is a issue. New Vettes operate at lower RPM's on the highway. On average road grades my motor happily turns 1400 RPM @ 45 MPH with no problems, 1900@60, 2200@70, 2500@80.
My car is a daily driver in the summer, so I chose gears, cam, and stall speed to match my driving style and the speeds I would be driving in real life 99% of the time. My torque converter is a 1600 stall lock up converter to be more specific. My cam may be considered mild. I am running the LT4 hot cam. I chose it so I would have good torque at the speeds I actually drive. It gives me great throttle response and drive ability in. We all dream of more HP and it takes some discipline to pick a cam to match our driving styles and not go overboard. For a daily driver too much cam is worse then not enough. My car is a 80 with the weaker rear end setup and so far with my mild cam I have managed to break a u-joint, yolk, and half shaft messing around on the street. Dave
Old Nov 10, 2015 | 09:13 AM
diehrd's Avatar
diehrd
Some good info here and some conflicting info.
The rear gear needs to be steep enough to keep motor RPM in a area where the power out put is not over taxed in normal driving conditions.
But not steep enough as to cancel out the 700R4 low first ratio . ( 3.06)
Gkull: I used 3.92 it was almost perfect .. But do agree a need to stay with 3.55 and above in most cases fills the sweet spot.
Stall converter , you need recommendations from cam manufacture .. Stall should be matched or closely to what the cam maker is saying it requires.
Old Nov 10, 2015 | 09:40 AM
Kacyc3's Avatar
Kacyc3
from the way it sounds to me you would have more fun with a 373 around town and still be highway friendly if you wanted to take a long trip. I 355s in my car and its great on the interstate but if I ever have a problem with it I'll do the 3.70 12 bolt option
Old Nov 10, 2015 | 11:37 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Hi guys
Rookie suggestion: With 450 H.P. "snappy" is already solved (just turn the "lock-up switch" OFF when driving in town/it will save wear on the transmission by not allowing the converter to constantly lock/unlock in city traffic).
Those weekend cruises are going to determine the diff. gearing. Engage the "lock-up" module on the open road.
I would keep the engine at 2500 rpm or less going 70mph.....look at it as "saving revolutions" on the engine (2900 rpm vs. 2500 rpm....400 rpm X 60 minutes X 4 hours/round trip = 96,000 "saved" rpm divided by 2500 rpm @ 70 mph.
You just saved approx. 1/2 hour of engine wear on a single 4 hour round trip.
Old Nov 10, 2015 | 12:37 PM
gkull's Avatar
gkull
Your 2200 - 2500 is fine it keeps your motor from lugging. The myth is that lower rpm = higher mpg. Well it takes a certain amount of HP to go say 70 on a level freeway. If you try to do it at 1800 rpm you would have to have a wider throttle opening to make the same amount of power as the gearing doing over 2000 rpm.
700r4 also has bad gear spacing. first is too low and second is too high. Going with 3.73 or 3.90 closes this spacing up. Even with 4.11 I could go about 90 in second gear
As to the stall: If you buy highly efficient 9.5 inch like from Precision Industries. Like the Vigilante TC Just get a 3500 with or without lockup. It doesn't really matter i only noticed a couple hundred rpm change in lockup. I drove mine for two years without lockup because my 5 lockup clutch unit went bad. Lockup clutches can't take much TQ before they start slipping. You can run the bigger pump and the pressure will help couple the plates. But that is why they came up with the multi clutch faces to more than triple the clutch faces holding Square inches.
To C3 Diff gearing for TH700
Old Nov 10, 2015 | 12:43 PM
toobroketoretire
Default 3.73 Gears
On my recommendation quite a few TH700R4 owners have installed 3.73's and are tickled pink over the results.
Old Nov 10, 2015 | 04:10 PM
EDDIEJ82's Avatar
EDDIEJ82
See my Signature for my specs. I have a little more hp than you, but close.
For your first question: Definitely go with the 3:73. You will never regret it. It's been so long since I did mine, but I sent it to a company in Pennsylvania that specializes in vette rears. Excellent work, I'll try to find the name of the company if you are interested, just let me know.
For the second question: I went through/burnt up 3 cheap converters before I found one that wouldn't break.The best converter you can put in there and hold up is a Vigilanti. I went with their 9.5 multi disk lock up with 3400 stall. I know this sounds like too much for the street but this converter drives around town better than my cheap 2500 and 2700 stall converters did. Also the lock up function works great with the overdrive. It honestly feels like a stock converter when I'm driving around town but turns into a BEAST when I stomp on it. They are not cheap and they build everyone to the specs of your particular car. I love mine. I feel like it is the perfect setup for my car.
Old Nov 10, 2015 | 05:21 PM
Steve scott
Cruising
What you saying makes sense.
Below are my Cam specs.
Hydraulic Roller Camshafts for OE Roller Applications
180265-10 Duration @ .050 IN 233 OUT 241
2400-5800 rpm Rough idle, Hot Street & Bracket Racing. 10.0:1-up CR 2800 rpm + stall
This seems to be going pear shape?
I either work with this or get the next cam down that's milder with a 1600 to 5400 rpm range.
