Engine knocking noise
Old Nov 10, 2015 | 07:37 AM
NORTON69's Avatar
NORTON69
2nd Gear
Default Engine knocking noise
Hi everyone,
It's my first message on this forum!
I live in France and i have a corvette C3 of 1969.
I bought this car from the us 4 years ago.
My problem is : since the beginning, i have an engine knocking noise.
the noise looks like coming from the engine case.
2 years ago, i changed and tuned hydraulic valves but still the same noise.
When i watch videos on youtube, it looks likes a bush bearings (shells).
I continue drinving with this noise more than 5.000 miles.
When i asked to my dealer if it could be a bearings he said not it's impossible because when a bearing is dead you cannot drive more than a few kilometers.
Is that true?
What do you think of this? My knocking engine could came from bearings?
Many thanks in advance for your help,
cheers,
Norton69
Old Nov 10, 2015 | 08:03 AM
toobroketoretire's Avatar
toobroketoretire
Cut a piece of garden hose about 4 feet long. With your engine idling hold one end of the hose to your ear (while plugging your other ear) while probing over your engine with the other end of the hose. By using a hose to listen you can easily pinpoint the exact place where the noise is coming from. Quite often a knocking noise is actually a leaking exhaust manifold that makes a loud "tapping" noise when that cylinder fires. And when the engine is idling if the tapping noise suddenly gets LOUD when you suddenly open the throttle that is a sure sign of a leaking exhaust manifold.
Old Nov 10, 2015 | 08:09 AM
NORTON69's Avatar
NORTON69
2nd Gear
Thanks toobroketoretire for your answer.
I forgot : the noise is loud the 2 first minutes when the engine is cold. Then 5 minutes the noise is low.
It changes your notice?
Thanks,
Old Nov 10, 2015 | 10:55 AM
kjr6306's Avatar
kjr6306
Probably not a bearing if you have been driving for that long with the engine noise. I'm no expert, but it sounds like may a bad hydraulic lifter. Also, if your bearing went bad your oil pressure would be low. Also could be exhaust leak....
Old Nov 10, 2015 | 11:23 AM
REELAV8R's Avatar
REELAV8R
How would you classify the noise?
Clacking- sharp, loud and faster than the RPM's?
Knocking- muted and seems in time with the engine RPM's?
Or Rumbling- deep and grumbling type of noise?
Old Nov 10, 2015 | 11:30 AM
toobroketoretire
Thanks,
It still sounds like a leaking exhaust manifold. Many people use exhaust manifold gaskets during a rebuild but those gaskets eventually burn out and then you hear a tap tap tap tap tap tap tap right where the gasket is blown out. Try the garden hose trick and see what you can find. With the engine idling probe all around the manifold where it fastens to the head. Remember to plug the ear you're not using so you can find the source of the noise easier. Foam ear plugs work great for plugging the other ear.
Old Nov 11, 2015 | 09:46 AM
SH-60B's Avatar
SH-60B
Hi everyone,
Is that true?
cheers,
Norton69
You can easily diagnose a bad bearing, if the noise really is a bad bearing. It's a two step process.
Step One: Place member "toobroketoretire" on your ignore list.
Step Two: If this knock can be heard clearly from the bottom of the motor; While the motor is running, remove and replace one spark plug wire at a time. If a rod bearing is bad the knocking noise will be greatly reduced when you remove that cylinder's wire. If the noise is not reduced by removing the plug wires, it is likely a bad main bearing.
There are many possible sources for an engine knock. Loose pulley, disbanded harmonic balancer, loose flywheel, etc. Happy hunting!
Old Nov 11, 2015 | 10:16 AM
toobroketoretire
Default Engines With Forged Pistons
Engines with forged pistons are fairly noisy until they warm up so its always best to wait until the engine has been operated for up to an hour before trying to diagnose an internal noise. The 340 hp and up engines used forged pistons and as forged pistons have about .005" clearance they WILL make a knocking sound until they thoroughly warm up. If you remove the oil pan you can tell if the pistons are forged just by how they are made as the undersides of the pistons are very smooth with a polished appearance.
Old Nov 11, 2015 | 10:30 PM
hpxt's Avatar
hpxt
Hi everyone,
Is that true?
cheers,
Norton69
Norton,
Welcome to the forum.
I doubt its your bearings. Unfortunately I have first hand experience; I recently blew my motor and developed rod knock. The engine seized after about a block.
Here is a short utube video that has a good explanation/sound on the problem.
Good luck with your Vette,
Mike
Old Nov 12, 2015 | 02:10 PM
centuryoldracer's Avatar
centuryoldracer
It could be exhaust leaks, and as the engine heats up they quiet from the expansion of the manifolds. Check the exhaust bolts and see if they are loose.
My first vette was a 68 with a 327 and I chased a dull knock for a year. I finally took it out and replaced it with a 427, and found several cracked piston skirts, and a loose wrist pin. Nothing broken off laying in the oil pan though.
If I had beat on it it probably would have blown up eventually.
To Engine knocking noise
