reverse lockout for hurst?
Old Aug 26, 2002 | 11:26 PM
garagedweller2's Avatar
garagedweller2
Default reverse lockout for hurst?
i need a shark badly! is there a reverse lock out for the hurst comp+ shifter linkage or do you keep the t bar?
Old Aug 27, 2002 | 09:18 AM
Mack's Avatar
Mack
Default Re: reverse lockout for hurst? (garagedweller2)
If I understand the question, there is no lock-out like the original equipment shifter. There is a spring loaded gate and you have to purposely pull the shifter over into reverse.
Old Aug 27, 2002 | 11:06 AM
gerry72's Avatar
gerry72
The Competition + has no reverse lockout provision. You also can not retain the original lockout shifter since it will not bolt to the Hurst mechanism. You can buy a handle that appears stock, including a non-functional lockout release, but having a release pawl isn't really necessary with the Hurst since the gate, unlike the factory mechanism, is fairly heavily biased against the reverse gate and it takes a purposeful effort to engage reverse.
To reverse lockout for hurst?
