Intake port filling
When I bought them they were advertised as 180 cc's. The as cast size was around 195 cc's when they arrived. At the time I knew that it was not ideal for my 350 with the performance goals I had in mind.
I did a little porting on them before install and this increased the volume to about 196 to 197 cc's.
The engine has performed well in spite of the too large intake runners, but my peak torque is later than I would like and it appears that peak HP will be above 6000 RPM, my self imposed RPM limit.
I believe that below peak torque performance could be improved with smaller port runners.
The idea is to increase the velocity of the charge to improve cylinder filling both below and above peak torque. Done right I think it could improve average HP significantly enough to make my efforts worth while.
I know I could buy better heads and be done with it. I would however like to experiment with these heads and try to learn a little about porting along the way. It's a dying skill and one I would like to learn about since I have the opportunity.
The question is how to fill in the runner reliably with minimal risk of epoxy breaking loose and being ingested by the engine.
A rough texture is a must, as I've read, and maybe even anchors in the form of screws in the intake from the outside, or grooves ground into the floor to anchor it.
The floor of the runner is what I want to fill to both reduce volume and increase radius on the short turn side of the port.
Has anyone here done this kind of thing? What epoxy did you use and did it stay in the port?
For me it has to last a few years. After that it will be different heads or a different engine.
Any advice on this kind of mod would be appreciated.
I'd juggle cam...it will have more impact on where TQ/HP hits vs the head port size.
Rectangular port BBC stuff often peaks below 6000 RPM even though the heads can carry 7000+ all day.
I ran some killer serious race ported 207cc heads on a sump piston 350 once. Chambers were cut to 55cc so I gained some compression. Used a mild LT-1 cam w/1.6 rockers and that thing worked great. Plenty of low end, would lug to 1000 RPM in high gear with 3.36's...and scream 7000 rpm when I wanted to.
JIM
Most street 350's like 106 Int CL.....see what you have and tighten it up to low torque curve.
I would do this before playing with epoxy....
Or try an even smaller head.....out of the box with blending.
Edelbrocks ol' RPM heads are 170cc......they are kick *** on a 350.
Sell the SHP's off....they should go quick.....
Do a killer 5 angle valve job on the RPM's and blend it in nice....
Jebby
The duration is relatively short as is. My last dyno indicated that the HP could peak around 6000 RPM, hard to say as it didn't get there. It only got to 5700 RPM due to secondaries not opening all the way and peaked at 406 HP, if I calculate 30% loss through the power train and accessories, but it was still climbing.
I don't think changing the duration or lift will have the desired effect.
I'm not looking to spin it faster. The CR is maxed with the current pistons and head which has been shaved almost to the intake valve seat giving me 61 cc's.
I could take, at most, another .008' off the heads without angle milling $$.
More CR could help a bit but would require significant effort and $$ to get it, making different heads the cheaper option.
I'm at high altitude where air density suffers and this, I believe, makes the low intake velocity problem more pronounced. I'm talking 4000 to 8000 feet depending on DA. 4000 ft would be at 55*. I don't drive much at that temp.
I've read many other forum's posts concerning filling ports and it can be done.
How successfully on a street driven car is a bit of a gamble.
Like Jim says it is usually a race application.
You're right..that is a pretty short cam already and on a 108 LSA...and a roller. It's a single pattern so if anything it's likely not helping the "hanging on" high RPM part and favors the mid/low range RPM's.
What intake?
Follow this thread. Certainly trust Larry Meaux and Darrin Morgan. Two of the best in the world.
http://speedtalk.com/forum/viewtopic.php?t=327
They point out a good question though...our new gasolines aren't going to be as friendly to most epoxies as race gas.
As mentioned, might be easier to sell them and get what you want.
Or just spin that 'lil motor up like it should be!
"Anything under 4000 RPM ought to be pulling into a parking place"!!
JIM
GM Fast Burn heads .
210 runner
2.0 intake
1.55 exhaust
You have heads that can be utilized and your posting you want to reduce there capacity , I suggest you get the right cam , induction and exhaust and you will be a lot further ahead.
higher altitude motors need to pack in as much as they can. Your best change would be to cut reversion by using longer duration, retarded valve events, and wide lsa like 112 or even 114
210 runner
2.0 intake
1.55 exhaust
I'm not looking to make a HP monster out of a 350, just a nice responsive, respectably torquey motor with a decent top end. I know I can't have it all. so 400 HP is good with me. More is just bonus.
My logic is this;
If I have suffecient velocity in the intake charge I can pack the cylinder better below peak torque and produce more torque down low.
Since I want and need to keep the duration short due to the thin air this additionally requires more velocity to fill the cylinder as much as possible above peak torque due to the shorter period of time to fill the cylinder because of the shorter duration.
If you can explain to me how with this cam or a similarly short duration cam and high DA you can pack the cylinder better with less velocity and more volume, I'm listening. I just can't wrap my head around how that could work as effectively vs more velocity.
For a greater duration cam, higher RPM engine, and at the sacrifice of low RPM torque with a higher RPM torque peak I can see it. That is not what I have or want.
These runners on these heads could be better utilized with higher RPM's and or greater displacement or for more HP at higher RPM's with this displacement. Maybe I could spin this engine to 6500 with my hydraulic retro roller lifters with better springs, but that is probably about it.
I'm looking to broaden the torque range as apposed to increase the HP at high RPM's.
If I'm figuring this right, increasing the velocity can do that without increasing the size of the overlap triangle or reducing below peak torque cylinder pressures.
What intake?
JIM
I did build a vacuum depression type flow bench last time I ported just as a comparison from as cast to my porting. It only works on a comparison basis.
I plan on doing something similar this time.
I'm not going to reduce the smallest CSA in the port. Just reduce the overall cc of the runner.
Thanks for the link I'll check it out. Have been doing a lot of reading over on speed talk.
But your also using a 350 , not much torque there to gain .. If it runs well you may be better off adjusting final drive ratio.
I also wonder why your worried about any rpm over 6000
Longer duration would create more intake reversion not less. Less velocity allows for more intake reversion as I understand it.
The 108 allows for a stronger pull on the incoming charge during overlap allowing for more velocity into the chamber creating better packing giving a higher peak torque.
A question for anyone here.
Has anyone built an NA engine for high altitude use? If so what where your considerations on cam, CR and runner size and what were the results of that build?
So like I said before retarded cam timing, wide lobe centers, as much duration as practical to fill the cylinders, and tuned intake runners/head ports
I lived in Denver for about 5 years and had to get used to a different way of thinking. Actually had to do just like you and think through everything. I realized just how easy it is at sea level by comparison. I messed with big blocks mainly, but it was similar. We ran all the compression we could stand, used ported oval ports (which work great at sea level also), and larger carbs...Dominators worked well with the oval ports. Cam selection is critical to pull it all together.
You might reach out to Mark Jones at VortecPro in Colorado Springs. He builds some killer combinations using mild parts that just fly. Recently it was a 10 second 454 based deal with the tiniest "peanut port" heads, around 10.0 compression, off the shelf Summit flat tappet cam. Runs deep 10's in a full weight Chevelle..at altitude!!
If I was thinking through a high altitude combination...Mark is who I'd call.
JIM
My intention is to only fill the floor. The roof I might raise if there is room, otherwise it will remain unchanged.
I want to fill the floor all the way to the short turn and blend it in to create a larger short turn radius.
May require blending into the intake manifold as well. As it is I know the manifold port is smaller than the head port, so it may not require much if any blending.
trying an annular booster carburetor to improve the signal?
No problems with signal to the carb.
I will build a vacuum depression type bench to flow the heads with a vacuum cleaner. It's what I did the first time I ported. I can get about 19" of water vacuum that way. I'm also aware that not every improvement shows up on a flow bench. Port shape is critical to a functional port.
Worst case scenario I have to pull the heads and undo what I did or move up my plans to get better heads.
Education can be expensive. Anybody looked at the price of college these days? And that is learning 90% BS that has no practical application in your life or career.
Only engines that are too small under them.
