1978 corvette wont do anything when key is turned
Old Nov 17, 2015 | 01:55 AM
millhouse2's Avatar
millhouse2
5th Gear
Default 1978 corvette wont do anything when key is turned
Hello I am new to the forum. I recently bought a 1978 corvette. It was running when I bought it but due to the safety inspection in Hawaii I could drive it cause it didn't pass safety. So I had to change out the power steering pump due to a leak. After changing that out ad putting the alternator back on I go and try to start the car and nothing zero. No power no crank no turn over absolutely nothing happens no power to the lights antenna anything. So I changed out the starter thought that could be the problem that didn't work. Changed the ignition switch that didn't work. Check all the fuses and fusible links, to my knowledge non of them are broke from what I read if you can pull them or if they are soft on either side they are no good. I am really confused on what it is and I think that it is something simple that I am missing. Please any help would be amazing I am running out of ideas as to what it could be. It has a 350 motor with a 4 speed manual trans. Thank you
Old Nov 17, 2015 | 02:49 AM
toobroketoretire's Avatar
toobroketoretire
It sounds like you have a dead battery. Somewhere along the way you may have left the door ajar enough to turn the courtesy and dome lights on which drained your battery. So before doing anything else charge your battery and see if it'll crank. Yes, it no doubt is a simple problem but you got flustered and started throwing new parts into it when the old parts were actually good.
Old Nov 17, 2015 | 05:16 PM
Snoopysvet's Avatar
Snoopysvet
Make sure the car is in PARK
Yes it happened to me! lol
Old Nov 17, 2015 | 05:28 PM
toobroketoretire
Ha, I have done stupid things like that too and as I age I seem to be making more and more of them. Sad, huh? I have left my ignition switch in the ON position a couple of times recently and found my battery stone dead the next morning so its likely he just made a simple mistake and caused his problem.
Old Nov 17, 2015 | 05:40 PM
65GGvert's Avatar
65GGvert
Not being in park won't cause the lights and antenna not to work. You need to start with your meter leads on the battery and then move methodically down the line to find where you're losing your power. You'll probably find it somewhere near the battery cables or the ground going to the frame. Don't just replace parts, measure and find what's bad
Old Nov 17, 2015 | 10:29 PM
64roadster's Avatar
64roadster
St. Jude Donor '07
I was recently working on my '64 and all of a sudden I lost all electrical power, nothing at all. This is a total frame-off restoration with all new wiring and most other electrical components. I started searching through all the main wiring connections and found nothing wrong. Finally checked my battery and it barely had a pulse. I put a charge on it and everything is back to normal. I guess 7 or 8 years on a battery isn't too bad.
Old Nov 17, 2015 | 10:53 PM
millhouse2's Avatar
millhouse2
5th Gear
The battery is brand new and in order to not drain it completely dead I unhook the battery every time I am done working on the car as a just in case. The battery is reading with a meter at 12.30 I know that is a little low I think that it is suppose to be at 12.40 or higher but not higher then 14.0 if that is correct please let me know. Thank you
Old Nov 17, 2015 | 10:57 PM
hpxt's Avatar
hpxt
Welcome to the forum, I too have a 78 in Hawaii. Small world, thought I was the only Hawaii C3 on the forum.
As others' mentioned if you ruled out the battery, could be a ground issue. I had a similar problem, both the battery cable and ground was bad. Replaced it and fixed the problem.
Mike
Old Nov 17, 2015 | 11:07 PM
millhouse2's Avatar
millhouse2
5th Gear
Mike
OK I will take a look at the battery cable itself I have checked and cleaned the ground. The battery cables are the new style ones or at least to me they are new and they screw into the side of the battery instead of on the top like I'm use to seeing it was a good thing is it better or worse.
Old Nov 17, 2015 | 11:52 PM
hpxt's Avatar
hpxt
I don't like the side mounts either. Forgot to mention you can check continuity with a multimeter.
Mike
Old Nov 18, 2015 | 12:09 AM
OMF's Avatar
OMF
I assume the battery connections have already been checked.
I have seen where the side mount bolts tighten but the cable is nowhere close to the battery....the bolts are too long. Confirm that they are the correct length.
Are you checking the ground cable where it bolts to the frame just underneath below the battery box?
Also use your multi meter to check the voltage at the starter itself, it should be a solid 12v.
There should be a ground cable from the engine to the frame right close to the starter as well.
Check all those out and report back.
Old Nov 18, 2015 | 12:25 AM
sug's Avatar
sug
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Have you tried pushing the clutch in when starting .
Old Nov 18, 2015 | 08:13 AM
65GGvert's Avatar
65GGvert
How do you propose that the clutch can cause no lights or power antenna?
Old Nov 18, 2015 | 10:39 AM
7t9l82's Avatar
7t9l82
Check your ground cable from the battery to the frame. It's copper clad aluminum and prone to corrosion from those stupid side terminal batteries G.M thought were so great.
Old Nov 18, 2015 | 09:25 PM
donnie1956's Avatar
donnie1956
You should have 12v at the big lug on the starter at all times. Thats where the main cable from battery to starter. Do you have a schematic of your model?
Old May 13, 2024 | 04:43 AM
1978jm's Avatar
1978jm
2nd Gear
Default Hey what’s up just wondering if you think I got the same problems lol
  • I don’t think it’s 100% my battery because my head lights still work but my interior lights don’t turn on, also when keys are in ignition nothing happens no clicking or anything.
Old May 13, 2024 | 07:44 AM
augiedoggy's Avatar
augiedoggy
Best to start your own thread on this rather than post in this conversation from 9 years ago.
Old May 13, 2024 | 08:17 AM
7t9l82's Avatar
7t9l82
Battery ground cable!!!!!
To 1978 corvette wont do anything when key is turned
