No start issue
Rodney
To set them with the engine running you back the adjustment nuts off until you hear a CLACK CLACK CLACK then tighten the adjustment nuts down until the CLACKING stops then one full turn down from there.
To set them with the engine stopped you bar the engine over to TDC for cylinder #1, loosen the adjustment nut JUST until the push rod can be spun freely with your fingertips, then tighten it down one full turn. Bar the engine over 90 degrees to TDC of cylinder #8 and adjust those two lifters. Bar the engine over 90 degrees to TDC of cylinder #4 and adjust those two lifters and so on; the whole process taking two full turns of the crankshaft in 90 degree increments.
If you adjusted all 16 of your lifters at one time without barring the engine over 90 degrees for TDC of each cylinder all of your valves are being held slightly open and none of the cylinders would fire.
Then check points to be sure you have them right. And make sure firing order is ok and cap is seated correctly
What would be the best way to get back to a base line to see if it then at least fires?
Thanks for everyone's help on this.
Assuming you actually got the lifter adjustment correct you likely have the distributor in 180 degrees off. As you have a compression tester screw it into the #1 hole then bump it over while watching the gauge. When you see the needle rising its approaching TDC of #1. Continue bumping it over about 1/3rd turn more until the timing mark on the damper lines up with the 0 on the timing tab. THAT is TDC of #1.
Now take your distributor cap off and the rotor SHOULD be pointing at the 11 o'clock position (#1). If its pointing at the 5 o'clock position you have it 180 degrees off (likely done when you removed the distributor to replace the stripped point's screw).
Get it positioned correctly and it'll fire off and you'll get a BIG poop eating grin on your face.
USA-OAC, assuming you have a hydraulic cam use the EO/IC method. Here's an article that explains in depth: http://www.google.com/url?sa=t&rct=j...9C4bsflQVYuRSQ
If you motor has a mechanical cam the method is different, but you can still be assured you're on the base circle with EO/IC
Turned motor over 1 complete revolution. Loosened all valves for that sequence to almost end of threads. Plenty loose. Adjusted valves as in 1st sequence.
Checked compression again and had 150lbs.
Tried to start motor but would not fire. It did however sound like a normal engine again rather that the whizzing sound it was making with valves to tight.
Tomorrows plan is to verify spark and that points are set to 16*. My plugs may also get replaced if needed.
You're not understanding something. After you adjust the lifters of #1 you bump the engine over 90 degrees then adjust #8. Then another 90 degrees and adjust #4. Keep going on 90 degree increments until you have adjusted all 16 lifters.
It ran perfectly until you decided to "fix it" and now it doesn't run. Logic would say you did something dreadfully wrong during your lifter adjustment.
Are you aware the cylinders on the left bank are 1 3 5 7 and the right bank are 2 4 6 8 ?
do you have a dwell meter to adjust the points to 30 degrees?
pull the coil wire out of the cap, hold it with insulated pliers and while having someone cranking the engine hold it near some metal ground to see if you have a spark.
Exhaust valves
#6 fully compressed adjust #1
#5 fully compressed adjust #8
#7 fully compressed adjust #4
#2 fully compressed adjust #3
#1 fully compressed adjust #6
#8 fully compressed adjust #5
#4 fully compressed adjust #7
#3 fully compressed adjust #2
Inlet valves
That worked for me hope you find this helpful.
Today I checked for spark, no spark. Measured point gap and they looked ok at 16*. Checked out coil. Tested a few tenths under speck for primary side. Took it up to NAPA to have it replaced. Cool counter guy said don't waste your money cause coil is not the problem. Double check very carefully the points again. Back home I go to look at the points one more time. After checking point spring action and readjusting gap I stabbed the ignition with key one more time and BOOM! She came alive as if asking what the heck my problem has been the last few days!
Its been raining here in Oregon (nw) for the last 2 weeks so after setting dwell, timing and idle speed in the morning I'm taking her for a nice well deserved cruise.
Thanks for everyone's help with this. It has been real educational.
